Um...J1772 and CCS1 will inconvenience Tesla owners for years to come if it is ever adopted. It really sounds like you rarely ever use TPC charging handles if you are making this argument.
J1772/CCS1 differs from J3068/CCS2 in a subtle but crucial way: the locking mechanism on J1772/CCS1 is actuated by a button on the handle and lifts a small latch that goes over little bump on the car's port and then slides into a notch behind the bump. If the vehicle wishes to lock the handle to the car, something descends from the top of the port and presses against the latch to prevent it from being lifted (or alternately, a hole can be provided just above the button if it's a private EVSE and the user can put a padlock through the hole, which also prevents the button from being pressed and hence the latch from being lifted). However, on the TPC and J3068/CCS2 design, the charging handle has
zero moving parts, and has a notch on top. When inserted into the charge port, something descends from above the charge port and inserts itself into the notch, which prevents the handle from being removed.
Now first of all, with a button on top of the handle on J1772 and CCS1 that controls the lever, where is Tesla supposed to put its button that controls the RF transmitter that opens the charge port? Well, Tesla had a solution for this on its
J1772 Wall Connector, which briefly went on sale last year before it disappeared from the store again: it left the latter out! Yes, that's right, the best feature of Tesla's Wall Connector and Mobile Connector was left off of its J1772 Wall Connector! I'm telling you, it's the easiest thing when you get home to just pick up the Wall Connector handle, press the button once, have the charge port open automatically, and insert the handle. Then before you leave, you just press the button on the handle once to unlock it, remove it, and put it back in the side of the Wall Connector, and the charge port closes automatically.
Second, at public EVSEs, it seems like every now and then, I come across a broken connector. I've only ever seen one part of these connectors break, and it's always the same darn part. Can you guess what that is? Oh right, the latch. The button and bottom part of the latch are always still attached to the handle, while the upper part of the latch has broken off. And CCS1, by inheriting J1772's crappy latch design, also inherits this problem.
