I have experienced one incompatibility out of three to four CHAdeMO chargers in Japan, especially Nissan's slim model. I think they are less common in NL and other parts of Europe.
Please share any incompatibility information such as charger brand. I asked Tesla charging team to fix the issues but currently they are not listening.
I wonder if skn tried the adapter with a near empty battery already?
I have my doubts as the software says you can accept DC charging or not; it can't differentiate between plugs AFAIK.
While I haven't been reading threads here as deeply as I used to, as of 3 months ago, the methods that were used by Tesla to generate DC in the US Superchargers (individual 10 kW chargers using 277V L-N, balanced across phases on 480VAC L-L 3-phase service) are the same methods that Tesla uses internally to the car in Europe (3 individual "sub-chargers" that use 230V L-N, balanced across phases on 400VAC L-L 3-phase service). There's no reason to suspect that Tesla does anything differently, unless there are some places it cannot get a wye based 3-phase service. In that case, I'd like to understand it a bit better. There's no reason the same Supercharger cabinets can't be used in Europe vs. the US (although European cabinets will need more of the chargers because L-N is 230VAC vs. 277VAC). In both cases, 15 chargers in the cabinet (5 each phase) is sufficient to produce 135 kW (230V * 40A * 15 chargers = 138 kW Europe, vs. 277V * 40A * 15 chargers = 166 kW US).
The CHAdeMO we use here are most of the time combined with AC 43kW. and Combo 60-100kW. In 2013 we had CHAdeMO with AC chargers, that were very bad (Nissan) and all were changed with mostly ABB chargers. If you have the Nissan ones, I also think they are high maintenance, and seems maintenance was not the top priority of Nissan as I can recal. The chargers aircooling system were full of dust and other nasty stuff which eventualy made the chargers break down.
The newer EU chargers run on 480V via step-up transformers and can deliver 150kW total split between the two pedestals. I have charged at 120kW on one while the neighbour got 30kW on his (same SC, he had a nearly empty battery also). The step-up transformers are rated at 160kW input but there are some losses in the transformer and the chargers.
Max for one car is still ~120kW (I have seen 122kW once).
Sure? I checked Koge in Denmark last week, brand new, SuperCharger Gen II 135kW maximum.The newer EU chargers run on 480V via step-up transformers and can deliver 150kW total split between the two pedestals. I have charged at 120kW on one while the neighbour got 30kW on his (same SC, he had a nearly empty battery also). The step-up transformers are rated at 160kW input but there are some losses in the transformer and the chargers.
The 135kW limit is for a single car, not the total power split between two cars. But you won't get 135kW in a Model S as that assumes 340A at 400V. At 400V the amperage is way lower in the S. Try charging two TMS with low batteries on the same SC there and I'm sure you will see at least 150kW in total (probably 120kW on the first car and 30kW on the second).
Same goes for the older 120kW SCs like the one on Lillehammer, max for one car is about 106kW. Not 120kW.
How'd you find out you are #59?
E-Mail the EU shop and ask.
