The most common red-light cause with the UMC is a ground fault / bad ground. You should check the ground connection for the receptacle. The UMC tests to ensure that there is voltage potential between L1 and ground; and if there is not, it will provide a red-light error. The car will report "cycle wall power".
If you are getting a red light on both 120V and 240V - different receptacles on different circuits - it seems your UMC may have gone bad. You may want to try carrying your UMC to another outlet somewhere on the other side of the house to see if it lights up green there.
But, the UMC lights up green on all outlets. The car reads plenty of volts, but it receives 0 Amps. As for trying another outlet, bear in mind that the downward spiral began by trying my charger in my friends outlet.
- - - Updated - - -
It has happened to me now as well. I have to take the car into the svc center tomorrow. Not too happy about this.
So, this is 4 of us in the Chicago area with cars that won't charge off the UMC? Elecblue - are you also post 4.3?
