Looking at your picture, one could make a case for a full service charging. One where after plugging in they wash your windshield.Arrived with 13% battery and with the batteries conditioned but I have never seen a charge rate like this on my car. What is the highest people have had?
If the pathetically inadequate scooshers fitted on Teslas did a better job the windscreen would be perfectly clean.Looking at your picture, one could make a case for a full service charging. One where after plugging in they wash your windshield.
Hold the button in until the screen is clean? Above average in my book.If the pathetically inadequate scooshers fitted on Teslas did a better job the windscreen would be perfectly clean.
I do, but the pathetic dribble that comes out of the scooshers is completely inadequate for cleaning a really dirty windscreen, such as salt from gritting in winter or the Saharan dust on Saturday. Well below average in my book.Hold the button in until the screen is clean? Above average in my book.
I've seen 250 but at any state of charge over ~30% in a MY, the charge curse is going down from 150kWh.Arrived with 13% battery and with the batteries conditioned but I have never seen a charge rate like this on my car. What is the highest people have had?
Is it bad etiquette to deliberately park next to another car at a V2 so that you charger more slowly and have time to get some food before the nags startI've seen 250 but at any state of charge over ~30% in a MY, the charge curse is going down from 150kWh.
Once I got that in my head, it helped me realise that other than if the v2 Superchargers were busy and load sharing, I could just as easily use those with little overall impact on longer drives since I'd probably be charging 20% to 80% anyway and using the time for a break.
The 250kWh part of the curve is great at the beginning and if you regularly charge from 10 to 40% only.
never did this - just increased target SOCIs it bad etiquette to deliberately park next to another car at a V2 so that you charger more slowly and have time to get some food before the nags start
I’m just letting you know that this isn’t necessarily normal! Might be worth further investigation. Even a very dirty screen should clear within a couple of wipes if holding the button. I live in an area with plenty of mud and particularly heavy salting during the winter. (We also got the Sahara dust a few days ago so specifically had to do the wash/wipe of the screen before a trip … and it cleared perfectly.)I do, but the pathetic dribble that comes out of the scooshers is completely inadequate for cleaning a really dirty windscreen, such as salt from gritting in winter or the Saharan dust on Saturday. Well below average in my book.
You raise a good point, I haven't thought of it that way but will bear that tip in mind next time I want a longer lunchIs it bad etiquette to deliberately park next to another car at a V2 so that you charger more slowly and have time to get some food before the nags start
The LG packs were limited to 175kW ish intially. A firmware update a few months later unlocked the full beans. This guy did a few videos on the charge curve, including this one where the speed improved.I think the highest rate I've seen on my car (2021 M3LR) is around 185kW when I was starting from a similar SOC . I haven't needed to use a supercharger for a while, it might be firmware upgrades have increased the max charge rates or perhaps it was a colder day?
I have heard this many times but I think it is an urban myth. Based on my experience if am at a V2 and someone plugs in at the partner stall my charge rate invariably drops significantly .but I think, once you join the next one to you, original one charges still faster than you (who joined party later) and you become main charger consumer once that person leaves, and so next poor sod will have low charging speed while you will be higher... I think... no?
Based on the streaks the windshield wipers and scooshers have nothing to do with it. Looks like the windshield was cleaned with a candy bar.If the pathetically inadequate scooshers fitted on Teslas did a better job the windscreen would be perfectly clean.
