absolutly 'no go' for europe , there is (still) only one option :
By the way, have any car manufacturers announced that they intend to offer this SAE DC socket?
anyway, at the long term, public charging will be inductive.
Then what's the point? Surely having fewer plugs on a charging station is also a goal as well as reducing the number of sockets on the car?
As was pointed out before, it looks like the new DC pins would block you from trying to plug that assembly into an AC only J1772 socket.
I thought Tesla was going to use a proprietery connector with adapters?As for who will use it first... well the timing and power level certainly fits Model S.
...Any reason why e.g. the LEAF couldn't have a CHAdeMO alongside the combo SAE connector and make use of the DC side of J1772 too?...
+1There are too many connector types as it is. This only adds to the confusion. Unless you are an enthusiast, all of these different standards/connector types will make your head explode. Not good for the public's perception of EVs.
DC Fast Charge Systems - SAE
Based off the AC charging standard
Interfaces are the same as AC standard with the addition DC contacts and serial data link between vehicle and off-board charger
The fundamental difference between the SAE and JARI/TEPCO fast charge systems is the type of ground used between the charger and vehicle
SAE uses an “earth” ground strategy while JARI/TEPCO uses a “reference” ground strategy
I don't think they put signalling on the power pins...
SAE J1772 goes further still by uniquely defining communications between an EV/PHEV, off-board charger, and the smart grid. Power Line Communications (PLC) is defined in SAE J1772 as the technology for enabling these vehicle-to-grid communications, without requiring changes such as the addition of another pin to the coupler architecture.
That's where IEEE comes in. PLC implementations from both the HD-PLC Alliance and HomePlug Powerline Alliance are based on IEEE 1901-2010, the world's most mature, robust, and advanced Broadband over Powerline standard. And the IEEE 1901 Inter-System Protocol prevents interference when the different PLC implementations are operated within close proximity of one another.
Hmm... We must embrace the new SAE 'combo' standard because the "smart grid demands it"? Resistance is futile...?...The drive toward an SAE J1772 combo solution illustrates the need for the strategic partnership recently forged by the IEEE-SA and SAE—and, more broadly, the coordination across historically disparate technology spaces and organizations that is demanded by the smart grid...
Oh... Multiple 'task forces'... No wonder it is taking a while to get implemented....Another example is the ongoing IEEE P2030.1 "Guide for Electric-Sourced Transportation Infrastructure" standards project. Work is being carried out by four task forces—vehicle technology (including charging systems), electric grid (from generation to consumer), roadmap (including privacy and roaming), and communication/cyber security—and then integrated within the full working group for broader discussion and input...
Sounds like they are in the 'herding cats' process....IEEE, meanwhile, has more than 100 standards and standards in development relevant to the smart grid...
