Look...
It doesn't help when Tesla fans throw shade at GM over things like this.
I can't help myself, I must confess that I am solely driven by the need to justify my level of cynicism...
RT
Look...
"Our EV range test involves some mixed driving."Too bad CR didn't provide even more details about their testing drive cycle so we could even better understand the results.
Please do, if you know about any Model S that left the owner on the road-side due to drive-train failure!
I think you are mixing up a purely cosmetic issue (noise in case of Model S) and a fatal failure (stranded roadside by Bolt).
My drivetrain was replaced due to the noise under warranty free of charge while I was driving a loaner Model S for the day, no drama or inconvenience.
Teslabjorn recently got stranded in his X after it quit on him with 14 km left on the GOM... think he said something about battery cell imbalance. Not sure what the final verdict was, but he's driving around a Leaf currently...
CR follows up on Bolt vs S75 range test controversy:
How Consumer Reports Tests Electric-Vehicle Range
Tesla expected 250 miles at 67-ish mph from an 85 kWh Model S
Final verdict is what would happen to any BEV at very low SOC. A big power draw will cause the voltage to sag low enough to abruptly cause the vehicle to decide the pack is below the minimum voltage threshold and shut down the pack. Since he was towing, that was even easier to achieve. The cells were very well balanced, especially since Bjorn does a lot of full pack cycles and often charges high enough to cause the top balancing circuits to kick in.
As for Bjorn's pack:
Again, large power draw at very low SOC will cause voltage drop enough for the BMS to shut down the traction pack to avoid damage. This is endemic of all BEVs.
A couple mile MPH is a big difference. At 65 mph the Tesla estimate approaches 260 miles range. The CR drive cycle is being misconstrued as a 65 mph test when it most definitely is not.Yes, basically, one should be able to hit EPA range in a Tesla Model S at 65 mph with one passenger, no HVAC, mostly flat terrain.
Sounds like they didn't account for hysteresis? The fact that gauges need time to settle. The obvious programmer's choice would be a warning and a taper to limp mode.
I can pull a bunch of amps from a battery and watch the voltage sag to under the minimum threshold during the load. But the instant I kill the load, it returns to nominal.
I noticed the same thing. It offers a bit more insight (like how they disabled regen on the Tesla), but still not htat useful. I guess it reconfirms this was not done at steady 65mph, but still doesn't tell us how much mixed driving was done. Even a rough percentage number (10%? 50%?) would have been useful."Our EV range test involves some mixed driving."
CR, is that really the best you can do ?
For a publication founded on transparency, CR has fallen into disrepute.I noticed the same thing. It offers a bit more insight (like how they disabled regen on the Tesla), but still not htat useful. I guess it reconfirms this was not done at steady 65mph, but still doesn't tell us how much mixed driving was done. Even a rough percentage number (10%? 50%?) would have been useful.
My interpretation is that their test protocol is a deliberate secret. Under pressure, they let a few details slip out but the reader is basically supposed to trust them. Obviously many readers don't.I noticed the same thing. It offers a bit more insight (like how they disabled regen on the Tesla), but still not htat useful. I guess it reconfirms this was not done at steady 65mph, but still doesn't tell us how much mixed driving was done. Even a rough percentage number (10%? 50%?) would have been useful.
