brucet999
The question was Volt/Bolt Charging.
It took a whopping 60 minutes to make both the adapter and a quad 120v outlet. Left is L1 / Right is L2. small blade L & R = 244 vac 1 ph unloaded, 241 while charging.
While a Tesla charger does not violate physical laws, it does violate Build Codes and Safety if Brucet999 is correct.
Your description of a home-made adapter to run a Chevy EVSE at 240V leaves out a lot of information. Where did you find a 240V source for your 60-minute "quad 120V outlet"? Unless that outlet happens to be supplied by a three-wire circuit, there won't be 240V available in any 120V outlet box. In my experience, it is rare to find more than one 120V outlet circuit in most garages, and the likelihood is only 50% that any two circuits will not be on the same bus at the panel. Much less likely in a garage is a 240V 15A or a 3-wire circuit. Most such 3-wire circuits were 20A, so if that is what you have, I hope you changed the breakers to 15A in your panel.
Many houses from the 60s to 90s have a 30A dryer plug in the garage, but more recently laundry facilities have tended to be installed inside the house. I wouldn't suggest installing an adapter for a Chevy EVSE on a dryer circuit unless you swap out the breaker for a15A one.
Code violation? Tesla UMC uses adapters for various outlet types' capacities. It will not allow more than 80% of nominal capacity of an outlet to be used for charging the car, so there is no violation of electrical code and no danger of overloading a circuit. It is also smart enough to reduce charging rate below 80%, or to even terminate charging, if voltage anomalies are detected in the circuit.
