SageBrush
REJECT Fascism
The wrong direction. It will be so much more expensive than not dumping it in the first placeMaybe this is a very small step in the right direction.
I don’t think it’s the wrong direction, per se, unless people use it as an excuse to keep doing what we’re doing. Do both - continue to reduce emissions but at some point in the future, we may find that some kind of capture is necessary regardless of efficiency or cost.The wrong direction. It will be so much more expensive than not dumping it in the first place
Indeed, that is the problem.unless
Full article at:Canada's grassland birds are disappearing and time is running out to save them, according to a new report.
Since 1970, grassland bird populations that live on the Prairies have declined by 57 per cent, according to the report from the North American Bird Conservation Initiative.
For those birds that are tolerant of agriculture, the decline has been somewhat blunted, with a decrease of 37 per cent, while birds who rely on native fescue grasses have plummeted by 87 per cent.
"In the last decade, 80 per cent of bird species newly assessed as threatened or endangered in Canada have been aerial insectivores or grassland birds," reads the report.
<snip>
Using less will not clean up the mess.Upset about the plastic crisis? Stop trying so hard
Just as the most effective technique for weight loss is to eat less, the most effective technique for reducing our environmental impact is to produce or consume less. There is no greener packaging than no packaging. No trip is greener than the one we didn’t make. No product is greener than the one we didn’t buy. When it comes to the environment, one of the most powerful and effective paths to sustainability appears to be inaction.
It won't make it worse.Using less will not clean up the mess.
First rule. When you find yourself in a hole, stop digging.Using less will not clean up the mess.
Absolutely. I fully embrace the idea of not using one-time use plastic, but the tenor of the article you posted rubbed me the wrong way since clean-up is *really* important.First rule. When you find yourself in a hole, stop digging.
I too had my doubts about the article. It did have a good point. Stop consuming, pumping oil, etc.Absolutely. I fully embrace the idea of not using one-time use plastic, but the tenor of the article you posted rubbed me the wrong way since clean-up is *really* important.
