jimm01
The most annoying thing about rooftop solar, to me, is that I like complex houses with complex roofs and neighborhoods with large mature trees, whereas rooftop solar works best with limited or immature trees and basic shaped houses with simple roofs. I could use a house with a field in back where I can install ground level solar, but hard to find reasonably priced property of that size that is still serviced by city sewer and city services like fiber internet.
Roof architecture (complexity) comes and goes, think Victorian and Craftsman. Not only is an architecturally ornate roof a bear to work on, the real issue occurs if there are problems. The more complex a roof is the more potential there is for leaks, (Occam’s razor applies). Tracking a leak on a complex roof may take some effort—then there’s fixing it. A more complex roof equates to more flashing and that’s were most leaks occur.
Although modern materials make shingling a complex roof relatively easier (still no fun) they are also not as resilient. This makes workmanship more critical, however in my experience the opposite is true. With cost reduction being the goal speed is the primary motive since it has a direct relationship to the cost of labor. Due mostly to construction and not materials a life time for a modern house is 25 years give or take. Not all new homes are built this way (watch This Old House). But if Tom Silva and the boys aren’t supervising, good luck.
