THIS IS TOTAL SPECULATION:
With this boat, SpaceX has an ocean going helipad. Another possible use for it might be to assist in fairing capture by having the helicopter grab the parachute of the falling fairing to guide it to the capture net.
Well yes, but that doesn't mean it can't be used for other purposes.I think that helipad is to rapidly evacuate crew upon spash down, if need for medical reasons. (if I remember correctly)
Wait, the solar panels don’t wrap all the way around the trunk? Man, those are efficient! But it means keeping the craft pointed the right way all the time. I assume the “old” deplorable panels they had could be rotated/oriented a little. Maybe?"Preparing to return human spaceflight capabilities to the United States, Crew Dragon and Falcon 9 went vertical at historic Launch Complex 39A in Florida."
SpaceX on Twitter
An article summing everything up:
Falcon 9 with Dragon 2 rolls out for DM-1 dry dress rehearsal at 39A – NASASpaceFlight.com
SpaceX on Twitter
...deplorable panels...
Another Elon Tweet about Commercial Crew. "You Must Be At Least This Tall to Ride!"]
The attitude of the spacecraft means there's not a lot of value in putting cells around the circumference of the trunk. It probably won't actually rotate much relative to the earth, other than a moon-like 360 degrees in pitch per orbit. (If you like, imagine a plane flying around the world--it would do exactly one pitch 'loop' for every lap). That's good for a few things, not the least of which is passenger comfort.
There's no point in collecting a lot more than that, because you quickly run out of places to put it, and you'll just need bigger shunts to burn off the excess power (which of course produce heat, and then the thermal weenies get involved...).
Elon Musk (@elonmusk) | Twitter
...or at least someone really hauled the sign up there for the photo op.Some might think that sign was digitally added to this photo, but knowing Elon’s sense of humor I would not rule out the crew gantry really having such a sign next to the door of the Crew Dragon.
May be accurate, NASA requires minimum height of 58.5 inches for a non pilot/commander astronaut:...or at least someone really hauled the sign up there for the photo op.
The 7 requirements to be an astronautTo be a commander or pilot astronaut, you need to be 158 to 190cm tall, NASA says.
To be a mission specialist, however, there a little more leeway – “between 58.5 and 76 inches” which is 149 to 193cm.
Demo-1 delayed to February:
SpaceX Crew Dragon mission to ISS delayed yet again — CNET
From the horse's mouth: SpaceX Demo-1 Launch Update – Commercial Crew ProgramDemo-1 delayed to February:
