wws
A EVSE is basically a fancy extension cord. It checks for ground faults, and tells the on-board charger that is buried in the car the max current (not voltage) the circuit can handle. It then turns power on and off at the direction of the on-board charger. This is why so many of us cringe when people (even some well-known YouTube personalities who definitely know better) call an EVSE a "charger".
NEMA plugs and receptacles include:
NEMA 5 (and TT-30): 120V only
NEMA 6: 240V only
NEMA 14 (and obsolete NEMA 10): 120/240V
When using a 14- (or 10-) series connection, EVSEs generally use the 240V portion - leaving the neutral blade unused. One certainly could use the neutral and one of the hots to bring 120V to the car. But why would you want to? You'd charge at half speed. And the on-board chargers on some non-Tesla cars even further limit 120V charging to 12 amps - regardless of what the EVSE says the max current can be.
A large RV does want both 120 and 240V. Besides splitting 120V loads between the two hots, they can also run more energy intensive things like air conditioning using 240V as needed.
NEMA 6: 240V only
