JerseyShoreMY
Have you any problems with the wire getting into the garage door wheels there?$850 for an installation of a wall connector on a 60amp circuit and a fairly good run of wire (pic attached). Not sure how that would compare to an installation of a nema 14-50 . Also not sure if the cost of a nema 14-50 outlet is officially qualified for the EV charging station tax credit, but it probably passes muster. Total cost of the charger and install was $1,350 ~ $945 net of tax credit. I'll take it for a safe system installed by a pro since I have absolutely no business messing around with that much juice.
Mine is only 10" wide between the door rails, and so even though the middle is the logical place, I may install it on the outer wall? Thoughts?
