Model 3 currently on 2023.12.5.4. Seems like once again my dash cam keeps giving the “red x” icon. I do a 2 button reset and then it works for a couple of drives and then it stops working again. Are others still having issues?
More likely buggy software on Tesla's side than actual drive problems. The amount of data being recorded is not much. There's another forum member who laid out all the data and compared it to what normal USB drives can handle and it's clear the drives should be nowhere near being worn out prematurely due to excess data writing.The drive may be going bad. It doesn't seem as if many options can handle the stress that it gets.
That sounds like the device is going bad.I thought the latest update fixed it. For the first couple of days, the Dashcam was working fine. Then got in the car this morning, Red X again. Did a 2 button re-set, started working again.
(Would be better for you to have posted this as a new thread. That would keep this thread topic clear AND give more visibility to your question. But, I'll go along.)Dashcam question (2023 Model 3) - My wife was hit (someone changed lanes right into her). She did not hit the save dashcam button but the dashcam is set on auto. The car is brand new so still learning...the dashcam did not save any footage from what I can tell. I thought auto was supposed to save if an accident is detected. Does that mean the dashcam did not function properly? User error?
BTW My problem was solved by manually creating the folders on the drive. Which I had to do by copying my bosses drive. I could find no reference online that correctly described the correct folder names and locations.Reply here since the site wont let me make a new post. I just installed a brand new Samsung T7 SSD per recommendations from this forum. Format worked, but still no dash cam. (did this while super charging and posting this from the supercharger).
Pre-2021 cars you use one of the USB plugs in the center console.How does one know if one has dash cam ? The option is grayed out on my screen. Can it be added ?
Also, the manual talks about a USB port in the glove box (or did i get than wrong ?) and in any case, I don’t see it, can’t find it.
2020 Model 3 AWD LR
