The brake pedal should be at least 1/4" above the gas pedal.
My brake pedal is at least an inch higher than the accelerator pedal. Maybe p85s have less of a difference?
Looks like a bad master cylinder or leaking brake line to me.
Just FYI, in many jurisdictions (e.g. here) it is illegal to drive without shoes on. Get some ballet slippers or something...
What is the rational behind that? I Drive with no shoes all the time and can't imagine why it would be more dangerous than with shoes. Actually I think it's safer cause I can feel the pedal and can control speed better with my toes.
Plus the guy posting the video is going crazy in the comments, obviously trying to drum up FUD.
Yeah. His proof is a Norwegian forum it looks like. Seems a lot like someone who used to post here and did the same thing.
Thought I'll take a couple of selfies, of my foot:
- on the accelerator
- on the brake pedal
Hmm, I'm indeed dangerously close to slipping off the edge of the brake pedal with my size 11.5 shoes. Hasn't happened but, is likely if I'm not careful.
With all due respect, why are you putting your foot on the right side of the brake pedal while your foot hangs over? You have over 50% of the brake pedal available to the left of your foot that is being unused. This is clearly a photo of user error. Look at your foot. It's not even centered over the brake.
Most cars have an accelerator lower than the height of the brake. To go from brake to accelerator requires a sideways movement AND a drop towards the floor. That is the separation that Tesla can change.
I think that many are missing the point that there are TWO directions in which the pedals can be separated. One is the horizontal distance - increasing this increases distance needed to travel to brake. Ok, possibly a safety issue. But the other is the height of the pedals. Most cars have an accelerator lower than the height of the brake. To go from brake to accelerator requires a sideways movement AND a drop towards the floor. That is the separation that Tesla can change.
I don't have my car yet. I was going on Nolands measurements in the original article this thread is about:It's already more than an inch higher than the accelerator, are you saying it should be even higher?
But more telling is the vertical distance between the surfaces of the Model S pedals--a scant 1.6 inches.
This turned out to be notably less than any of the 22 other cars I measured.
They ranged from a low of 1.8 inches (the M3 and CR-V) to 2.9 inches (Chrysler Town & Country minivan) The average was 2.2 inches--nearly 40 percent greater than the Model S's miniscule vertical separation.
Guys its not the height off the floor , it's the height in front of the gas pedal towards your face. When you push down on the brake the edge of your foot should not touch the gas pedal till the brake is fully activated.
@Liuping there are 25K cars between your vin and mine maybe Tesla already fixed the problem?
* If you are actively braking, and then clip accelerator, there is NOT an accelerator cutoff, you get juice and braking at same time. If you accelerate first, then simultaneously brake, there is accelerator cutoff.
* I can fashion a permanent 1/2" thick brake pedal cover. Either find someone with 3d printer, or go prowl around home depot looking for materials.
Something tells me the writer of that article never was a fan of heel toe shifting :tongue:
