This is not correct. The setting is adjustable. I have mine set at 50 mph.Would have been nice to lower the setting for places like the toll road but my salesman said in response to my question that the computer doesn't take the vehicle to the lowest setting until after you cross a threshold speed of about 90 or 100 mph if I remember correctly.
The aerodynamic advantage increases as speed goes up, but it's not zero at 50. Originally 50 was the default, and was only changed due to the two fires--however the skid plates added fixed that problem. Also the handling is better when set to low.Thanks. The salesman claimed there was no aerodynamic advantage at 50 mph. If that's correct, a lower manual setting would not be efficient perhaps.
Air suspension= Mercedes or Lexus.
Coil suspension= Porsche or BMW.
I like Porsches and BMWs.
I got it because we have a lot of snow but I love it every day because it makes the ride a lot smoother and quieter. Had a loaner with coils this week and was surprised at how much road tire noise came through. Steering also seemed less precise.This is probably a dumb question but does the air suspension actually raise minimum ground clearance or just the body/angles? Also, my 2 cents is that it's nice to have but not a necessity unless you drive a lot of tough drive ways/speed bumps. For snow where I live the extra 1.3" probably isn't going to make a big difference, if you get the kind of snow where ground clearance matters you're probably going to want more than the air susp max anyway.
Oh OH..!!
I just thought of another reason why air suspension is excellent.
For some certain songs, when they play, you simply must slam the car while cruising the boulevard. At low speed.
My kids can predict songs where I reach for the button to slam. I also put my shades on, even if it is dark outside.
