bhuwan
We should expect from the battery curves we have been presented with: 3% loss of range the first year, and 1% for every year after. I would consider normal +/- 2% at the minimum.
Bens numbers seem to fall outside of that!
Of course they take 265 as the start when they figure out percentage, even though I started at 273. But my 254 is still more than 3% loss. But I don't know what "the first year" means.
Which member name is ben? What were his full range charge numbers? Battery capacity? Total miles? Delivery date?
If he is outside of that, then he may have a developing issue that he needs to watch.
From the graph I reviewed, 'one year" was the time from when the battery first started cycling power.
So turning that into numbers...
265*.9 = 238.5
.97*265*.9 = 231
"First year is that 10K, 12K or 15K miles?"
Taking out the 5 questionable datapoints (203,265,273,275,277) the survey number average is 234 for a 90% charge, which is inline with these numbers. Perhaps a hair low.
I still am confused why they range ranges so much...
Once you remove the extraneous data, I think your numbers start make some good sense. You should note that you did not ask users for their true mileage which I think would create a more clear trend line from ~235 to ~220 against miles, rather you asked them for their longest trip tick distance. Some users have kept this to be their total mileage, many have not.
Also, because you are charging to 90% SOC NOT 90% of 265 miles your numbers below are a bit off. Assuming for a second that their is an 80 kWh useable battery:
90% SOC -> 72kWh -> ~5.3kWh (Reserve) + 66.7 kWh (drivable above 0 and displayed)
66.7 kWh displayed = 66.7 kWh/0.287 kWh/mi = 232 miles displayed on the dash in "rated range" mode.
My car came with ~84kWh drivable energy, which would show about 244 at 90% (275 at 100%).
Now it's about ~78kWh drivable energy, which would show about 227 at 90% (255 at 100%).
This seems inline with your data and other cars.
Peter
My survey was trying to see if there was a relationship between driving style and rated range, as I had been told that emphatically by Tesla service personnel, so the survey was trying to see if there was that relationship. From the survey, I think that relationship is clearly debunked unless there is some short term thing, but there isn't any evidence out there on that either.
I did note that the mileage was perhaps related to total car mileage in the long report. I suspect there is some relationship in my data but definitely not certain. I think perhaps a different survey on battery degradation could be done at some point but I think we are too early for that. And plug in america has been doing those well, so I am going to assume they will be doing similar Model S surveys on that in the future.
I was finally get around to input my data by delaying the charge till a time when I was actually awake since my car normally charges in the middle of the night. But I could not get a full "daily charge" or non-range mode charge. The charge wants to stop just a hair before. Tried it a few times. It is 5 miles below my typical range number.
Any thoughts?
This is kind of odd, no? I thought one of the things we interpreted from prior data was that usage/cycles has a more significant impact than age except for the most extreme of "garage queens" (i.e. sub-1000 miles, 10+ years old).'First Year' refers to a calendar function and has nothing to do with 'Miles'
Hi Lloyd,
Charge termination at a particular partial SOC is very hard to do consistently, especially with various charging currents. It also seems to be an area that Tesla has been trying to refine throughout the software loads. I have given up using anything except for full, 100% range charges to track my degradation, and to compare against others cars.
Peter
Quote Originally Posted by bluetinc View Post
Hi Lloyd,
Peter
