I Think that page is only available to those with a login - the public page is TeslaFi.com Firmware Tracker
Anyone in the UK got the new update that includes the ability to schedule charging to a particular departure time?
I am really looking forward to that as it should largely prevent limited regen in a cold morning.
I haven’t noticed home charging benefiting limited Regen, I don’t think it has enough umph compared to DC charging
Might be worth navigating to Supercharger, if one is available nearby, to fool the car into battery heating
I haven’t noticed home charging benefitting limited Regen, I don’t think it has enough umph compared to DC charging
Will be interesting to see if the new "Precondition for departure time" runs the battery heater or Stators (or is that the same thing?) to heat the battery more.
supercharger preconditioning only happens when car is in drive,
If it's because you like the 1-pedal driving experience and regard limited regen as spoiling that, then fine - tricks to heat the battery will help, but it will cost you money.
the carbon ‘payback’ from a PV panel at about a years production
I only have MS experience in past winters, but once into proper winter, temperatures 0C - 5C say, then definitely have limited regen on morning departure, and charging for an hour or more immediately before departure doesn't fix it (it maybe reduces it ...)
hmmm... can you direct me to instructions for Teslafi as to how? All I can see there is that this has been a support request for over two years (and therefore not yet possible?)You can do that today using Teslafi.
Her viewpoint is that there is "X" CO2 in building North Sea Wind and "Z" for the PV panels I buy.
For my personal electricity use my portion of X would be less than Z. However, North Sea Wind not fully rolled out yet:
If I use regular Grid electricity until North Sea Wind is fully rolled out, using an additional "Y" amount of CO2 as a consequence, then X + Y will still less than Z, so on that basis I should wait for North Sea Wind rather than put PV panels on my roof.
It may be splitting hairs, in the case of PV, but I found it an interesting viewpoint for other things that emit a lot of CO2 in production (concrete / construction materials) and has moved my thinking away from "offset against whole of life" being OK/sufficient. Any CO2 we produce, now, is a problem ... until we have figured out how to properly offset that and stabilise the atmosphere, which is going to take several decades to achieve.
Sorry, have wandered off topic.
