Frustrated over here. I, too, had expectation that reaching 310 miles should have been possible making it that I could go to the next city and back in a day on a single charge. That's impossible unless maybe driving 50mph on a turnpike which is beyond dangerous.
Took 2 round trips 122 miles away this weekend, so I'll break it down into 4 trips. Temps 80-86, driving on Chill, AC on auto but barely needing to blow due to weather.
1. 122 miles, 75mph on 75-80 miles of turnpike, used 60% of battery. That's 200 mile range and 375Wh/mi
2. (return possibly tailwind and net -500ft elevation) 110 miles from Supercharger, 47% battery used. 320Wh/mi, 234 mile range. 2 way average of 217 mile range vs 310!
Since I knew I'd have a Supercharger stop anyway, I decided to keep up with traffic better:
3. 122 miles, 80mph on turnpike, used 68% (damp roads on half trip increased friction), equates to 418Wh/mi, 179 mile range
4. 109 mile return, 80mph on turnpike, roads dry, 55% battery used, 378Wh/mi, so 206 mile rage. 2 way average 189 mile range!
Yes, 80mph is deemed fast for an EV, but maybe this is the Achilles heel that nobody wants to address. If I knew that keeping up with traffic would mean I have to take a 40%+ range hit and not even in winter, I probably wouldn't have done this. Around town, I don't care that I only get 320Wh/mi lifetime average. But to use it for road trips would be amazing, yet it's such a hassle.
I'm still trying to get a local person to swap me their 18's for a couple of days to 1) see if they fit with my rear spacers and 2) run tests and hope they would as well to see a RWD using the 20's. I'd buy a set of 18's even if it were just for road trips. As far as unsprung weight goes, it should be noted that the P brake rotors should save weight over the smaller 1 piece rotors of the other cars. The even larger MPP front rotors save 3+ pounds each. So while the 20's are about 4 pounds heavier than the 19's, the brakes could almost make up for that difference alone. Yes, the wheel rim being 10" from center vs 9" makes a bit of difference, but not cause 20%+ differential that owners are seeing.
Overall, I truly believe that there is a software issue that is not letting the front motor torque rest as it should. When in Chill, my understanding is that all cars are limited to 200hp. It should be no different than a RWD. Unless it needs power to the front, it shouldn't be consuming anything. Now that we're out of winter, I've been driving in Chill for a couple of weeks testing. Around town, I can get down to about 270Wh/mi virtually hypermiling. In town, virtually no highway, so it should maximize regen. to help me. I have even averaged 180 for a 5 mile average before bumping back up to 268-270Wh/mi average. I've driven the snot out of a RWD for a day that I rented before taking delivery of mine. I expected that if I drove similar, I should see similar efficiency. Not. At. All. Something is awry with the programming of the P's, and far too many RWD owners brush it off that you shouldn't care because you got a P (as they get better than advertised range), and then other P owners who amazingly don't care either. I didn't buy a SR or MR version. I wouldn't have pulled the trigger if that was my max range. I hold out hope that good ole Uncle Elon will be able to fix this with an OTA. In the meantime, my Y order is for a RWD w/ 18's.
Sorry you are frustrated.
There are several threads on this. Partially I've resurrected some of them, but not because I am upset with the range - I expected lower range, and I think I can comfortably get 260miles range driving the speed I need to in order to be safe (75mph on Southern California freeways), and 270 miles without difficulty if there's some traffic. It's well within what I expected. I resurrected the threads because I am also considering range wheels (with MXM4s and an 18" which can somehow be rigged with something aero), and I wanted to see just how much benefit I was likely to be able to get. It's also close to "no AC no heat" season now, so we can really see how the vehicle does from many people.
Rough values - I'm getting about 280Wh/mi on the freeway travelling 75-80mph with traffic (mild drafting, following distance 4-5), with no HVAC (AC off, temp set to LO, fan sometimes on, sometimes not). (Average speed worked out to 61mph.) I was not using Chill mode. Also not using AP too much (only when traffic was light).
(My brother in a P3D Stealth, for comparison, gets ~248Wh/mi under similar conditions & speeds, but with less drafting - with Aeros and MXM4s.) So I think that's pretty much the difference between PS4S and MXM4s - about 30Wh/mi (which is what I wanted to know).
Note you need to be at about 230Wh/mi on the in-car display (according to that meter, 71.3kWh appears to be available from 310 to 0, not 75kWh (242Wh/rmi)) to make the rated range, so even with that efficiency you won't quite make it - but I think it is acceptable.
My results seem to be significantly better than yours, so I do wonder if there is a vehicle issue in your case. A few questions:
1) You have PS4S, right?
2) Do you have any abnormal wear on any tires? It's possible you have excess toe and are doing a lot of scrubbing of the tires.
3) What PSI are you running? I run 45PSI cold (~48PSI when warmed up).
4) For the numbers you quote above, what were the indicated Wh/mi on the trip meter? It looks like you were not quoting those numbers, instead you were quoting what you thought you were effectively getting. That will give you higher numbers than I am quoting (I am quoting what the car says - which I don't necessarily trust in an absolute sense, but is what I have to go on - and I do think it reads a bit low).
To improve your efficiency, the only thing I can suggest is:
MINIMIZE use of regen (but do NOT run in low regen mode), but also do NOT use the brakes. So, you need to anticipate traffic ahead, and try to minimize the length of the green bar. You could run temporarily in low regen mode to get a feel for minimal regen, but in general you should run with standard regen.
BTW, my lifetime average is 287Wh/mi - but it has been steadily coming down as I don't use the power as much, and the weather is also warmer (though I basically never used the heat, intentionally). I don't think it will go below 280Wh/mi though - it's hilly in San Diego and I am FORCED to use regen, which is not efficient. This also includes 7 miles of autocross which increased the lifetime average by about 2Wh/mi.
