Jeremy3292
Update: Got the expected Corporate line and reference to the PW3 FAQ page.Update: Earlier date of 10/9 opened up and I snagged it. Have also inquired about PW3 with my advisor; will report back.
OK, thanks. But the worst case technically is this:
(a) In grid following mode (utility is up), the GW equivalent simply will not support CTs to track other solar inverters. So the PW3 charge behavior will ignore the other PV, you couldn't set it up to charge only from solar and count the 3rd party solar in that configuration. If you place the "house" CTs accordingly, the other PV will just appear to be a negative load, so the PW3 will still adjust its discharge behavior to only cover net load.
(b) In grid forming mode (utility is down), the grid forming inverter will not support AC charging of the batteries and will shut down if the attached microgrid has a net power production. I guess this is possible but seems pretty stupid. If this is the case, you just have to interconnect your other PV outside the GW so it won't be on the microgrid.
Cheers, Wayne
It may have that requirement to handle switchover to isolation better. The solar inverter may or may not kick off on transition.
Plus, the system may go for zero net current before the gateway disconnects, having other sources available complicates that.
It is possible that it might not have inputs for current monitors to attach to external inverter feeds, so it would have no way of knowing how much external PV was producing.All valid possibilities but unlikely any major technical issue that Tesla hasn't solved before in PW2. It's even possible the PW3 has the technical capability in HW design but intentionally crippled in firmware. Ultimately, it's more likely a business decision rather than insurmountable technical hurdles to not support third-party inverters in PW3.
Yeah I was 10/30 and then kept checking for reschedule dates and 10/9 popped up, a whole 3 weeks earlier than before.Same here, no mention if/when PW3 would be available but they also bumped my assessment from 10/25 to 10/2. Appears some spots might be opening up for folks putting their project on hold? (speculation)
See the quoted Tesla doc:
Discussion: Powerwall 3 [Speculation / Discussion etc]
Now I'm really torn...might have to go with Powerwall+/2 over waiting for Powerwall 3. I have a feeling installs aren't really gunna happen until at least April 2024 and even then probably going to be a limited supply. So realistically could be almost a year from today. If I can get my order...teslamotorsclub.com
It makes little sense technically to me as well but business motivation often trumps all else.
PW3 hasn’t technically been released yet; pricing is unknown.Interesting, Are they still going to produce Powerwall 2's? If not it definitely signals a move into a completely vertical environment - you can't have Powerwalls with Enphase or Solaredge systems, and no retrofit markets will work. I guess if you had Sunnyboy or Fronius string inverters you could rewire them into a Powerwall 3 and toss the old inverters, but that makes the economics even worse.
Powerwall pricing didn't seem to change either, so still a losing economic proposition, but will be interesting to see how the other solar vendors respond to this.
All this complexity makes me double down on waiting for a V2H vehicle as the core of an economic ESS system, which eliminates Tesla cars as an option, at least for now.
I read this article today and it implied the PW3 does not integrate with the PW2. Anyone know if this, correct?
The article says: "Powerwall 3, however, doesn’t play nice with other battery solutions, including Powerwall 2, and can’t work with other solar inverters. "
If I order Solar + Powerwall today, will I get Powerwall 3? If not, do you suggest that I wait until Powerwall 3 is available?
No, per FAQWill PW3s be available to non-Tesla solar folks? I recall reading this buried in some online source a few weeks ago. My plan is to add batteries to my PV system in the next 12 to 18 months. 2 PW3s would be the perfect solution but I don't have Tesla panels, Inverters, or combiner gear.
That isn't how it works. From the looks of it the PW3 is not designed to be able to integrate with an external solar system. You could probably install a PW3, but it would act like a standalone PW with no knowledge of solar. (So, no charging from solar when the grid was down, no solar self-consumption support, etc.)You should be able to order PW3 direct regardless of what your setup is but installation will be on you.
NoYou should be able to order PW3 direct regardless of what your setup is but installation will be on you.
If you were planning to order Tesla solar, would your order it today or wait for Powerwall 3 to become available, and why?
