Sogorman
I'm starting with the 20" Pirelli Cinturato P7 All Season Plus, which is a pretty quiet tire to begin with. Next up will be the 21" Michelin Pilot Super Sport XL, very noisy in comparison. The foam is 1" thick with a perforated vinyl layer on top and the layer I'll add weighs less than 16 ounces. It will be glued in with gel contact cement, which I've already tested.
Seeing the results of the 21" Super Sport will be interesting. Are you going to take baseline and post treatment Db reading? Also when you say, "The foam is 1" thick with a perforated vinyl layer on top and the layer I'll add weighs less than 16 ounces" what layer are you going to add? Is it the glue or something onto the foam in addition to the 1" stock foam from the factory?
