I know that it's recommend that you don't supercharge when you don't need to for the sake of battery wear, but how about using the full HPWC capacity? Is daily 72 amp charging ok, or is it better to keep it lower unless you need a quicker charge?
Most on this site will recommend daily charging between 80%-90%. I personally always charge to 90%. Using a 72A won’t hurt your battery.
I know that it's recommend that you don't supercharge when you don't need to for the sake of battery wear...
From the battery's perspective, that is already very very low rate charging, so it will not care. 240V times 72A is only 17kW. Remember that at a Supercharger, it can be up to about 100kW, so 17 is hardly anything to it.I know that it's recommend that you don't supercharge when you don't need to for the sake of battery wear, but how about using the full HPWC capacity? Is daily 72 amp charging ok, or is it better to keep it lower unless you need a quicker charge?
The other thing which might matter a little is what @Canuck mentioned. I don't like to run my charging equipment like a UMC or wall connector at its maximum amp rating all the time for daily use, because that does get a little hot, and heat is a bit hard on electronics and can shorten its life a bit. I use the UMC at home, and I have it set for about 31 or 32A instead of 40 to keep it a little cooler.
Yeah, I did see that's what you were talking about, but I was referring to the broader principle of not running something at its maximum rating every day.I was actually referring to the onboard charger(s) inside the vehicle and not the UMC or HPWC, which are not technically "chargers" but EVSEs (Electric Vehicle Supply Equipment). But I agree that dialling down the amps is good for them too.
