brkaus
As nice as that feature is in the winter, it’s still not the same.One big difference is you can simply pre heat the car from the app.
I really wanted heated steering wheel - but I figured I'd rather get a bigger battery so I could happily warm the entire car
With the Leaf I had to use the heated wheel because I could afford to use the car heater without dramatically reducing range, so I'd be driving with a thick jacket and hat to keep warm. Or be melting in the summer with AC set to 82.
Not an issue now though, AC on 72 and still using less energy than the Leaf while driving 10-15 mph faster.
I think you misunderstandmelting in the summer? AC doesn't use enough power to avoid. I leave my leafs set at 60F year round. If it's 75+ my AC is running (on the lowest fan speed if need be but I don't avoid running AC).*
Best thing about a proper plug in hybrid or full EV is that AC is practically free. Sitting in a parking lot or drive through you have no reason to turn it off. You don't have a gas engine running at a minimum RPM that still wastes gas because it provides more power than the AC uses. It just barely sips from the HV pack.
* If you had your leaf set at a warmer temp the Leaf will mix heat and AC to reach the desired temp. Wastes a ton of power, On older leafs you have to manually install a heat off switch, newer leafs have it stock. But so long as the heat is forced off with the overide switch AC is practically free. Even if you don't have the switch just setting the leaf to 60F all the time will avoid most of that heat blending.
AC in summer at 80 is because it’s 95-100 outside. Pretty sure the AC isn’t going to be mixing in heat at that point.
On a 2013 Leaf just push the HEAT button so the light goes out, if you want the heat to be able to come back on simply push the HEAT button again so the LED lights back up. Note pushing the AUTO button may also bring the HEAT back on, pushing HEAT again will turn it off.
Wow... have these guys never heard of duty cycles? This explains sooo much. I was wondering wtf it was turning on heat when I have it set to 72, and it’s 75 outside (I would turn off heat, and just let the fan blow).It does on the leaf if your set point is equal to the inside temperature of the car no matter how high or low the set point is. If you set the AC to 60F and it's 80F inside and 100F outside, fine no heat for you. If you set the AC for 78F and it's 78F in the car and 100F outside, bam the heater comes on to blend with the AC and hold it at 78F instead of accidentally letting it go below 78F. It'll actually kick on at low amounts for a 1 or 2 degree delta and kick on harder as the AC hits the set point and even harder if it hits below the set point.
Newer leafs have factory heat off switch that disables that behavior and older leafs can retrofit a similar aftermarket switch. But without that switch set to disable heat the Leaf will merrily turn on heat in the hottest summer days.
Stupid design but that is the Nissan Leaf for ya. The Nissan engineers were used to blending waste heat from the engine to keep the set temp moderated, no waste heat in the EV, well then we'll just turn on this handy resistant heater we put in the car...
If you still have a leaf you can confirm with the leafspy app and an ODBII dongle. Watch the heater come on during AC use.
On a 2011 or 2012 you have to buy an aftermarket mod such as Heater OFF switch on 1. gen. "plug &play" solution! - My Nissan Leaf Forum
That explains a lot.It does on the leaf if your set point is equal to the inside temperature of the car no matter how high or low the set point is. If you set the AC to 60F and it's 80F inside and 100F outside, fine no heat for you. If you set the AC for 78F and it's 78F in the car and 100F outside, bam the heater comes on to blend with the AC and hold it at 78F instead of accidentally letting it go below 78F. It'll actually kick on at low amounts for a 1 or 2 degree delta and kick on harder as the AC hits the set point and even harder if it hits below the set point.
I would wear gloves, but, it's hard to use the touch screen with them on. A heated steering wheel would be a nice feature.
Gloves that allow you to use a touch screen... I will have to look into that.Both my current car (a Chevy Volt) and my previous one (a VW Golf Cheating Diesel) had heated steering wheels, so the lack of this option on the supposedly more upscale Tesla Model 3 that I ordered last week is a disappointment. There are gloves that supposedly enable one to use touchscreen devices, so I figured I'd go shopping for them. Maybe now's the time to do that, too; with winter ending, gloves are likely to be in the close-out bins....
I'm just waiting on Elon to say that we've had heated steering wheels this whole time and it's now turned on with a software update...
