Door handle module
Discussion in 'Model S' started by mackgoo, Apr 8, 2017.
Tags:
  1. mackgoo
    mackgoo Member
    SoCal
    I'd like to fix the micro switch issue on one of my door handle. Is anyone aware of a good "how to" on actually removing the module from the door? Everything I've found so far has the module already out of the door.
  2. LoL Rick
    LoL Rick Like Buttah
    Land O Lakes, FL
  3. mackgoo
    mackgoo Member
    SoCal
    So I only scanned, but I didn't see where you remove the door handle module. Did I miss something?
  4. LoL Rick
    Land O Lakes, FL
    They didn't go that far. This one does, but on the rear door. You will need to be more careful than he is.
  5. Btr_ftw
    Btr_ftw Court Jester
    Mass
    I will be doing one for the front door as well.
  6. NiallDarwin
    NiallDarwin Right to Repair!
    New Zealand
    Did you yet?
    Cheers :)
  7. Muzzman1
    Muzzman1 Member
    Los Angeles
    I had a ranger come out and change out the micro switch harness today. Here's a few things I learned. ( I did not feel comfortable filming him)
    1.) After removing the door panel, he used a "spare" window switch to roll the window up and down as needed.
    2.) He Removed the glass. There's an access "rectangle" towards the front of the door that allows the plastic capture to easily get the glass out of the way
    3.) Once he got the harness replaced, he left the glass adjustment nut loose until he tested the glass fitment by closing the door and using a business card to check the seal tightness in the front and rear of the glass.
    Took him 15-20mins to knock the whole thing out.
    • Helpful x 3
  8. NiallDarwin
    New Zealand
    Thank you Muzzman1, very useful.
  9. NiallDarwin
    New Zealand
  10. freeewilly
    freeewilly Member
    Brea, CA
    With so many Tesla going out of warranty, this can become someone's full time job to replace door handles everyday.
  11. Lasttoy
    Lasttoy Active Member
    St Augustine, Fl
    I did right rear, took longer to get tools ready than remove it. On back you have to get in, raise window all the way up or you cant get to top bolt. I now have 3 spare mechanisms so i can change it in 15 minutes. Fix broken one later. The wiring harnesses are too tight, should be removed from holders do they dont break . I put Dynamat insulation in my door while i had panel off. There good videos on YouTube on this.
