My
My new travel kit is a 50ft NEMA 10-30 extension cord, the Tesla 10-30 UMC plug, and an adapter for NEMA 14-30 outlets. It's light and gives 240V at 24A charging from any dryer outlet. I tend to only use it at 16A to not push my luck and it still charges in <24 hrs.
Use a variety of household outlets to charge your Tesla with a Gen 2 NEMA Adapter. Simply attach the appropriate adapter to your Mobile Connector, plug into the corresponding outlet and begin charging. Adapter Max Distance Gained Per Hour of Charge Model S Model 3 Model X Model Y 5-15 3...
shop.tesla.com
Technically, you should use a NEMA 14-30 extension like this one: (
https://www.amazon.com/GearIT-Welder-Extension-14-30P-Charging/dp/B09ND3575T) , but then you have an extra conductor for nothing. And that adapter should ideally connect the ground to the third conductor on the NEMA 10-30, but it actually connects the neutral. Not ideal, but works.
