Dual chargers
Discussion in 'Model S' started by whitecotton, Jan 8, 2016.
Tags:
  1. whitecotton
    whitecotton Member
    Houston, Texas
    Do the Chargers work together when charging or independent of one another?
  2. JER
    JER Member
    Bristol, UK
    There must be some coordination to comply with set current limits and for scheduled charging. The power flow will of course be separate and in parallel, though.
  3. FlasherZ
    For anything over 40 amps, the primary charger will ramp up to 50% of the setting, then the secondary charger will turn on and contribute the other 50%. They are both managed together by the BMS and charging logic.
  4. StaceyS
    StaceyS Member
    Bend, OR United States
    And for anything less than 40 amps, the primary charger handles it exclusively. The secondary charger only comes on at amperages above 40 amps.
  5. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    Shame they don't split the load below. I've been hauling around a 2nd charger for 28,000 miles and think I've leveraged it once. maybe twice. mostly at the SC after repairs, so I can charge enough to get home.
  6. Rockster
    Rockster Active Member
    McKinney, TX
    I purposely charge at just over > 40 amps most of the time to ensure that I'm stressing both chargers. I figure if my second charger is going to go bad, I'd rather know that during my warranty period.
  7. Cottonwood
    Colorado
    It's also good to find a failure before you are relying on the dual chargers on a trip.
  8. andrewket
    andrewket Well-Known Member
    Which means if you have dual chargers and you're trying to minimize wear and tear, charge at 41A. Personally I charge at 70A regularly, and 80A when my SOC is below 30 miles.
  9. whitecotton
    whitecotton Member
    Houston, Texas
    Wow that's defiantly not the answer I was expecting! Another lesson learned!
  10. Ames
    Ames Member
    Abu Dhabi, UAE
    I wonder how this applies to the European 3 phase setup. Does the 2nd charger kick in if we exceed 16 amps?
  11. Canuck
    Canuck Well-Known Member
    South Surrey, BC
    Which is why I bought a HPWC for use at home, put a 14-50 plug on it, set it at 64 amps, dialed the car down to 42 amps, and put the UMC in the trunk.
  12. ArtInCT
    ArtInCT Always Learning
    Southern Connecticut
    I found out something interesting a few days ago when I was discussing the dual charger option with my local service manager. The second charger is essentially a slave. It does not add any high availability or redundancy to the car's charger capabilities. In other words, if the primary (standard) charger were to fail for some reason, the second charger is not going to take over for the failed primary charger. So it does not add any redundancy to the overall charging system.
    That said, I was told that Model S cars with the dual chargers can indeed have a failure in the second charger but the Primary charger will work with a failed second charger. I did not ask if the Model S senses or "knows" that the second charger is failed. I suspect you would have to exercise it with a charge of over 40 Amps?
  13. WarpedOne
    WarpedOne Supreme Premier
    Slovenia, Europe
    That is redundancy, just not 100% but 50%.
  14. andrewket
    Not really. The slave is only used for current above 40A. So yes, if you regularly charge above 40A and the slave fails you'll still be able to charge. It's arguably better than the X's single charger. But not much.
  15. ArtInCT
    Andy:
    I think he was kidding. WarpedOne just forgot to put the SMILEY emote on....
  16. andrewket
    Oh. Stupid Internet.
  17. Canuck
    South Surrey, BC
    What it does do, if you charge at say 42 amps, is only stress each charger at 21 amps on a daily basis. It seems to me that's likely to make both chargers, which are a high wear part, and require liquid cooling, last longer. That's just my guess though.
  18. ArtInCT
    Canuck you are right about that. I have a HPWC installed and will probably add the second charger and a center console after I have the S for a short while. Once I get the second charger installed I will always charge at about 50 or so amps set at the car with the HPWC set to go to 80 (if needed).
    Does anyone know if a failed second charger sends a notification to Tesla via a log entry or the owner via a displayed error message?
  19. BertL
    BertL Active Member
    Carlsbad, CA
    There is no notification to the owner. If it fails, the first way you'll know is your normally 79-80A HPWC charging will max out at 39-40A or so... Assuming you didn't set your MS to charge at a max of 40A, Tesla can then isolate it pretty closely via the logs as to if there is an issue with the 2nd charger or not. IMHO in the scheme of things, this isn't a huge concern as you will still be able to charge if a problem with the 2nd charger crops up -- just not as fast -- until resolution.
