Dual chargers
Discussion in 'Model S' started by irvineboy, Jan 22, 2016.
Tags:
  1. irvineboy
    irvineboy Member
    Irvine, CA
    #1 irvineboy, Jan 22, 2016
  2. stevezzzz
    stevezzzz R;SigS;P85D;SigX;S90D;XP100D;3LR
    Colorado
    Dual chargers have been optional for all but the Signature Model S. Since dual chargers are not listed, I think it's safe to assume that this P85 has only one.
  3. jerry33
    Texas
    They are now an after-sale add on. They used to be optional in the design studio. They were never standard. The easiest way to tell is to charge on an 80 amp HPWC and see if the charging stops at 40 amps or goes higher. You can also look under the rear seat, but it's very hard to get the rear seat back in if you've never done it before.
  4. wk057
    wk057 Senior Tinkerer
    Hickory, NC, USA
    Even easier... just go to the charging screen and try to set the amperage above 40 while not plugged in. If it goes to 80 then it's got two chargers.
    Can't really do that with a CPO not physically available to mess with though.
  5. Chickenlittle
    Chickenlittle Active Member
    Virginia
    Cheaper as add on. Is 2000 dollars, installed. Was 3500 if I remember correctly when an option on build
  6. pgiralt
    pgiralt Supporting Member
    Cary, NC
    No. When it was an option build it was $1500 from the factory or $3500 installed after the the fact by the service center. When they got rid of the option build, they reduced the service center installed option to from $3500 to $2000
  7. kwang
    kwang Member
    OC
    Quick noob question, would dual charger make any difference at Supercharger?!?
  8. mark
    mark Member
    Dallas
    No - DC Supercharger bypasses the AC on board chargers
  9. pgiralt
    Cary, NC
    No - not at all. The onboard chargers are not used for supercharging (except for some signaling that seems to pass through them).
  10. rfmurphy81
    rfmurphy81 Member
    Orange County, CA
    I've got a related stupid question, just because I honestly don't know. Would charging via CHAdeMO be limited by whether you have single charge or dual chargers? I understand CHAdeMO is similar to Supercharger in that it uses DC, but not sure if there are limiting factors in it.
  11. mmccord
    mmccord Member
    Pine Bush, NY
    No it would not be limited by this.
  12. irvineboy
    irvineboy Member
    Irvine, CA
    Oh so you can get it as a retrofit for $2000 parts and labor?
  13. deonb
    deonb Supporting Member
    Redmond, WA
    Yes. My advise - dont install it until you've been in at least one situation where a high speed charger was available and it would have made a difference in your travel time if you had dual chargers.
    Chances are pretty good that you'll never need / can use it.
  14. Clomer
    Clomer Member
    Colorado Springs
    Yes. It's on the Tesla Motors web site here: http://shop.teslamotors.com/collections/model-s-charging-adapters/products/2nd-onboard-charger. If it's a CPO car you're looking at, you could probably request that they install it before delivery. Even if not, they'll be able to install it shortly thereafter.
    I second this. Few people can make good use of the 2nd charger, as it doesn't affect supercharging (or the CHAdeMO adaptor). It's only useful when you connect to AC charging that is capable of greater than 40 amps. This might be at home if you install an 80 amp HPWC, and there are destination charging sites that have such charging, but the vast majority of public chargers are 24 amp J1772's where a 2nd charger would make no difference.
    Even with a single charger, you can go from completely empty to completely full overnight.
  15. stsanford
    stsanford Member
    Long Island, NY
    As an owner on my second MS, and now with Dual Chargers, I thought it was a waste, until I was forced due to some electrical issues at the house, to install the HPWC.
    Now my car charges on a normal day in 1-1.5 hours rather than the 3-4 I was seeing. If you have irregular driving needs, it makes things a lot easier to go full-electric. There have been a few days where I got home with enough charge to make errands and shopping with the family a tight squeeze, but 15 min on the charger made it a non-worry.
    Hope that helps some...
  16. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Exactly. I also have "irregular driving needs" and am very happy my S has dual chargers. I have also found HPWCs at destinations running at 60 to 80A and am glad that can charge faster and not tie up the HPWC for as long as those with a single charger. Well worth the extra cost, in my opinion.
  17. jerry33
    Texas
    Right. Destination chargers are a really good reason to have dual chargers.
  18. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    A year ago I would have skipped dual chargers as high power AC charging was very rare. But now I see over 1080 destination chargers listed. Impressive and now I would get dual chargers.
  19. tga
    tga Supporting Member
    New Hampshire
    But what percentage of those 1080 destination chargers are 80A (or even significantly >40A)?
    I don't recall any amperage minimum for the destination charging program...
  20. ecarfan
    San Mateo, CA
    We don't know the answer to the question you posed. I only know that I have charged at 60-80A from some I've used.
    And the Tesla Destination Charging program does not require a "amperage minimum.
    I believe that over time there will be an increasing percentage of chargers over 40A as EVs become more common.
