It comes in sheets with very strong adhesive. No tools necessary to apply except to trim with scissors but good idea to degrease/clean the surface, unless applying on top of the butyl layer; I’m a avid car detailer and use Gyeon Prep (essentially isopropyl alcohol surface prep) before applying the Noico stuff to ensure it sticks as good as possible. My Amazon order history shows I bought 3 of the PE foam kits (20sq ft, $50 each) and I’ve burned through almost all of it. I think the 4 wheel wells need about 1 and a half of kit.
@MyEarHurts the outer areas of the fenders that benefited from the butyl are not part of the rigid megacasting members on my May 2020 build car and you can see the welds attaching the sections and definitely made a lot of noise when tapping it.
The PE foam really works to keep out the noise. In fact the 3M Peltor noise protection earmuffs (
https://amzn.to/3xuALtL) I use are lined with the same sort of foam right by the ears. I’ll be doing the same to our Model 3 wheel wells which suffers from road/tire noise but doesn’t have any booming issue.
