This has nothing to do with the battery size. I have a 60 with duel chargers and I can charge up to 80A.It went right to 40/64 ... the 70 is a bigger 60 not a smaller 85 so only 1 charger is possible from what I know -- guess I just had to experience it for myself, looks like I'm maxxed-out at 40A for AC charging (which might change the $$$$ when I call an electrician for HPWC quote as there's no reason to feed it more than 32-40A... at the moment![]()
Even at 40A this is a very handy spot and since there's only 1 HPWC I imagine that's why some folks here may have not been too motivated to communicate more about itI should have tested the J1772 there too (I think it was Sun Country but not on their map ??) as I'd be fine dropping a bit lower to let someone take advantage of a lot faster charging on the HPWC with dual chargers.
Amazing that it's all still a "plug in and see what you get" affair... car is just so good, even propellerheads like me take the plunge without knowing all the facts, that really says something.
I get full power at Cobourg. It can't be the charge station because of the way J1772 signalling works. Something is up with your car.
I only have single charger....I get 40 amps.
Yes, but in that case it will say 40/40.
In that case, the behavior has changed from what it used to do.
Actually, I don't think that is correct. I only have one charger and if I recall correctly, I see the potential higher amperage even if I can't take advantage of it.
Meanwhile, back in Montréal, at 10:40 today (a Sunday) I had to wait 25 minutes to get one of the two Supercharger spots. (Picture above is from 11:10.) Well-known problem, I know.
One car's driver fell asleep. Maybe I should have nudged him with my horn.
The SC in Montreal really is a joke - 2 stalls... come on!
Do they have the typical fenced-in compound there with the Supercharger equipment in it? Has it been "roughed in" for more stalls? It might just be an electrical capacity issue from the utility in that area.
There's a little fenced off area but it's really small. See it's to the left of both stalls... On the right edge of this picture.
I remember reading somewhere that there are 4 stalls, 2 of which are available for the service center (inside the garage). If its the case, they are not visible from the part of the shop you leave you car when getting service...
Looks like the "Hamilton" supercharger location has officially been moved from coming in 2015 to coming in 2016. :-( I can't say that I'm surprised.
Same thing with Riviere-du-loop.
Port Hope still looks like it is planned for 2015, but I wouldn't be surprised if it misses the deadline by a month or two.
