At the risk of sounding like an anti-EV'er from 10 years ago, batteries just aren't ready for prime time in electric aviation (or boats).
The are 2 issues for planes:
- High continuous power demands
- Weight
Land EV's (cars, bikes, scooters, Segways) work great because the peak power demands are limited to bursts of acceleration. Cruise power is pretty low (the typical car needs 20-25 hp, or 15-20kW, at highway cruise), and weight doesn't really matter. The P85D may make 691hp, but only for a few seconds at a time. Try to take it on the track, and it overheats pretty quickly.
I'm looking at the pilot's operating handbook (POH) for a Cessna 172S. Some relevant specs:
- Basic empty weight: 1642 lbs, max takeoff weight (w/ fuel, baggage, and passengers): 2550lbs
- Engine is a Textron Lycoming 180hp IO-360
- Cruise parameters range from 45% power, 94ktas@6000ft, using ~7gph to 75% power, 121ktas@6000ft, using ~10gph
So the C172 uses 80-135hp, or 60-100kW, continuously, at cruise. Let's say we put an 85kWh Tesla pack in an electric C172. 2 things would happen:
- We'd burn through the pack in an hour or less (range would drop by 80%)
- More importantly, the plane would never get off the ground, since it would be several hundred pounds overweight.
Performance boats have lots of problems, too. Weight is less of an issue. Cooling isn't a problem, but you still need a big motor, lots of batteries, and lots of power at the dock to recharge.
EDIT - Sandpiper beat me to the punch. Oh well. :smile:
EDIT 2 - The Electraflyer has always interested me. I've always thought it would be pretty cool to build an electric ultralight trike. I haven't heard of the Sun Flyer, although I wonder how far off it is looking at their site (is it anything more then vaporware?). And putting solar cells on a GA plane makes about as much sense as putting solar panels on you Model S and expecting any really gain in range (this thing isn't Solar Impulse).
