eprosenx
Getting a second run of wire allows me to leave the dryer plugged in without worrying about someone trying to use it while charging too.
Getting to 32 amps will cost me about $650 getting to 48 would be around $1300 (for 60 amp, not sure what it would cost to get a 100 amp, but I only have a 200 amp panel too) Also, a 14-50 can be used for other things like the welder I may never buy Probably overkill for an electric homebrewing system too but another possible use for it. Hmmmm gotta make a decision eventually.
That is kind of surprising that the delta in cost is so large? Are you including the $500 HPWC in the second # but not including a HPWC or second UMC in the first number?
I personally always want a UMC in my car with me, so even if I was charging with the UMC at home I would buy a second unit to keep with me.
Also, what gauge is being planned for giving you 32 amps? Maybe just 8 gauge NM cable since you only need it rated to 40a? (I would always run a fully 50a capable circuit to a 14-50 generally even though the UMC Gen 2 only needs 40a/32a.
