the Tesla is sucking up about 33Kwh (if I am reading these graphs correctly) a day - charging from about 180miles to 270miles
now my commute is only 30 miles round trip..
270 - 180 =
90 miles of DAILY driving.
Your
commute is 30 miles round trip.
90 miles of daily driving - 30 miles of commuting to work = 60 DAILY miles of non-commuting driving.
So, every weekday, you drive 15 miles to work, then 15 miles home,
then 60 more miles around your neighborhood before plugging in and charging for the night?
You have a second job as an Uber driver? Are you delivering pizza in the evenings?
I get home and plug the car in about 9-10pm where it charges for about 3hours.
Are you plugging in to a 110 volt outlet? Are you using a 220 volt outlet? Do you have a hardwired High Power Wall Charger? Do you know how many amps you are charging at (You can find it on the display in the car)?
3 hours on a 110v outlet won't typically pull more than 4 kWh per day, but won't be enough to replace the 30 miles of commuting:
4000 watt hours / 250 watt hours per mile = only 16 miles of range added to the car.
3 hours on a 220v outlet charging at 16 amps (a NEMA 6-20 outlet) is likely to pull 10.56 kWh per day. That is more than enough to replace the 30 miles of commuting, but not nearly enough to cover the additional 60 miles of non-commuting driving per day:
10,560 watt hours / 250 watt hours per mile = 42 miles of range added to the car.
3 hours on a 220v outlet charging at 32 amps (a NEMA 6-50 outlet) is likely to pull about 21.12 kWh per day. That's enough to replace your 90 miles of daily driving as long as you are using less than 235 wh/mi:
21,120 watt hours / 234 watt hours per mile = 90.3 miles of range added to the car.
3 hours on a High Power Wall Charger charging at 48 amps is likely to pull about
31.68 kWh per day. That's enough to replace
more than 125 miles of daily driving as long as you are using less than 250 wh/mi:
31,680 watt hours / 250 watt hours per mile = 126.7 miles of range added to the car.
Notice that whatever your evening driving hobby is, it is costing you twice as much per day as your daily commute. So, if you are spending $200 per month on charging your car, then $67 of that is for your monthly commuting and the remaining $133 is for whatever your non-commuting 60 miles per day is.
