0.11¢ KWh as long as I don’t charge it between 1pm-7pm.
Monthly cost to drive my car = $33
Or use any appliance at home.
"Normally we have very low electric usage, about $50-60/month. If we run AC a few days a month that goes up to $120-160/month."
This is the line that has me curious. A few days or extra AC (is that simply 3 or more or 3-5 or half the month?), shouldn't increase one's bill 100%. If that were the case, the entire month with AC could end up costing you over 1000$, which can't be the case.
As others have said, you could be on tiers and you simply hit the tier 3 or 4 pricing, which can increase the $/kwh a LOT. Base rate in the Bay Area is .19, then it goes to .28, then it jumps to .46 and of course that is for EVERY hour of every device after that point. I have alerts setup to let me know if I'm getting close to Tier 3 (from Tier 2) or if for example I'm heading to Tier 4 which is usurious.
If you're at home a lot during says (or if someone else is) and or if you start the AC in the late afternoons to cool down a house in the summer time, a TOU rate starts to break down pretty quickly.
I've found/figured that if I'm in an AC period like the summer, or a very cold period in the winter, Im probably overall better off just supercharging at .26 in CA (vs. my Tier 2 rate of .28) so that only those hours are at that rate and not ALL my hours if I get up and over into Tier 2 or worse Tier 3.
It would not be the first time. Tapes reveal Enron's secret role in California's power blackoutsSomeone is getting taken massive advantage of.
My god, I can not believe how much folks report paying for electrical power in California. That is just insanity. I get that perhaps your supply mix is more expensive and *maybe* you have higher transmission costs, but it sounds like you guys are getting screwed on residential electrical. Feels like a method of environmental activism more than pure economics.
Here in Oregon I pay a little over 10c per kWh any time of day any day of the year. I find it hard to justify .46 per kWh peak when your off peak rate is only as low a .19. Someone is getting taken massive advantage of.
California population: 39,776,830
Oregon population: 4,199,563
I think the answer is in there somewhere.
I bet if you examine the electrical rates here and compare them to population, there will be no correlation. Nothing about population being a factor in the intro:It costs a lot more for electricity in CA due to the population alone.
Plus, they're the 5th largest economy. In the world.
Mine should increase about $0.50 a day based on my electric rate and charge time. The dollar amount will vary by both variables.I just got my electric bill and it was a bit of a shocker. Normally we have very low electric usage, about $50-60/month. If we run AC a few days a month that goes up to $120-160/month. This month my bill is about $390!
We have been running AC more than usual but I can only imagine the car charging is making up the difference. I have done about 500 miles so far in it over the last 2 weeks. Just wondered other people's experiences and what to expect
~$25 per month for 1000 miles of driving at 250Wh/mi, charging on PGE TOU with Green Source option.
That's about $175 in gas at 20mpg with $3.50 premium in my last car.
TOU is different in different areas. I can't shift my 4-9pm away from some AC in the summer and Heat / fan in the winter. Plus, I'm home about 2-3 days a week by then so it would push my costs up significantly compared to Tiered plans.Interesting, do you think TOU is a good deal for you? My car would be the only thing I could shift out of the peak usage time (other than that it is mainly AC since everything else is gas). The TOU option did not look that interesting to me.
I am on a solar net-metering setup so I don't obviously want to do anything to risk that (so not even sure TOU is an option but I have not looked into it).
(I am on Portland General Electric as well btw)
I might look into a second meter, and see if that might over 2-3 years be a better option.
LTR SVH. Insulation isn't really the problem, construction is. It's not a big overall load, but Tiered plans have some doghouse as the baseline. I can't really do PV unless I did some roll out and put it in as a secondary (not connected to the home) for EV only. Might do, cost is pretty low overall.House or apartment? Insulation + PV would help lower AC net use.
