The largest non-Tesla charging network, Electrify America, doesn't use ABB much anymore. (They were too reliable?) Their current main suppliers are SK Signet and BTC.
Indeed. I've seen that many EA sites that had ABB have been been getting replaced by something else or their next gen units.
Pismo Beach Premium Outlets - Nike Factory Store | Pismo Beach, CA | EV Station - I charged here when it was ABB.
Gilroy Premium Outlets (3) | Gilroy, CA | EV Station - ditto
Walmart Supercenter | Santa Clarita, CA | EV Station - ditto
Walmart Supercenter | Salinas, CA | EV Station - I've only charged here after it was already upgraded to next gen.
It seems the main failures people report are:
- Broken CCS1 connector.
- Mainly the latch, this is a CCS1 design problem.
- Failed cable cooling system. (Limiting the output to 50kW.)
- Other companies go with air cooled cables.
- Failed temperature sensor in CCS1 plug. (Limiting the output to 50kW.)
- Bad design in Huber+Suhner cables. (Old design required entire cable replacement, newer design supposedly allows field repairs.)
- Failing power modules. (Limiting the output.)
- Mainly in SK Signet equipment.
- Failed payment terminals/network
- EA seems to use Nayax ones.
- It looks like Tesla is going to use Payter terminals in V4 sites where regulations require card readers. (They are nicely integrated, not just bolted on the front like EA does.)
- Vending machines have had payment terminals forever and they don't seem to have the same failure rate...
- Signet surge: Likely a bug in Signet equipment that impacts >800v vehicles with bouncing output kW.
- If it is a bug, they should have been able to roll out a fix by now.
I've definitely seen the tang/latch broken at many EA sites, sometimes repeatedly. I've usually called those into EA when I see it. I had a hypothesis about why in some cases and mentioned it to EA. Only they would know whether my guess holds water.
For
Princeton Plaza Mall | San Jose, CA | EV Station, for example, it used to have BTC Power DC FCs (see old pics). The way that site is set up, w/the handles going into holsters on the front and the cables jutting out into the parking space, it's possible that cars in the way in/out are contacting the cables and then being pulled out of their holsters. That woud probably break the latch. The handle might also hit the pavement, possibly breaking the latch.
Bank of America | San Jose, CA | EV Station also used to have old BTC Power and the same setup. I've seen broken tangs at both sites numerous times.
Bank of America | San Jose, CA | EV Station are Signet "v2" and the holsters are on the side + are real nice the way the handles site inside the holes on the side. Also, the cable doesn't jut out as much. So, I'd guess this type would have fewer broken latches.
For the rest, I only have guesses as to why the tangs are getting broken. It could be dropping or clueless people. Some might be clueless thinking the plug is stuck to their car, so they use a lot of force, which would break the tang. And, others might actually be stuck due to a bug somewhere.
Interview: Electrify America expects you to raise hell if chargers don’t work mentions one from long ago:
"Other bugs include miscommunication between the vehicle and the charger. E-tron drivers have been unable to remove the cord after the session is completed. (That problem was on the vehicle side. Audi separately told us that a software update will be deployed this week to solve the issue.)"
For air cooled cables, well, yeah, if the power output is much lower. I'm unfortunately unfamiliar with air cooled only CCS1 cables and handles that can handle 150 or 350 kW. Also, FWIW, EA is kinda goofy on how they came up with their "150 kW" designation. As I mentioned at
Lucid Motors Air, I'd spotted a Lucid Air test vehicle in 2021 pulling 166 kW (on the charger's display) on a 150 kW unit. Was definitely an older BTC Power unit at
Princeton Plaza Mall | San Jose, CA | EV Station.
The power output problem is frustrating.
My Learnings From an EA Field Engineer - Important for... mentions:
"He also told me there are 3 temperature sensors at EA sites, one in the handle, one in the dispenser, and one at the inverter/power unit in the cabinets. These are prone to failure and cause de-rated speeds (20-30kW max) when they go bad."
The Signet surge/massive power level variation problem even affects 400 volt vehicles and CHAdeMO. I'll have to see if the reports of that at
Bank of America | San Jose, CA | EV Station are visible in their app as their web site seem to not let you go back real far in reviews.
You're right about Nayax being the vendor. That's what I've seen too. Also, as
https://insideevs.com/news/389891/exclusive-interview-electrify-america-problems-solutions/ mentions (search for card), there can be problems w/Nayax card readers specific to a given station vendor.
"For example, there have been problems with the Nayax credit card readers and after rounds of software revisions three of the four manufacturers appear to have the compatibility issue resolved (it's still in final validation) but one of the manufacturers hasn't managed to correct the problem yet. This happens all the time. When Electrify America identifies a problem, they need to work it out four times and that obviously causes these issues to take longer to resolve than they would if there were fewer equipment vendors."
