Ok, let me try to address some of these points without name calling...
1. Automatic Lane Changes:
- You are correct that the car would need to know what lane it is in, and what lane to be in... and you are correct in the inaccuracies of GPS. In general, GPS can get to as low as 0.01m in accuracy with post processing and correcting technologies, but without those, the best that is theoretically possible is about 2m, and 4m is more generally accepted as the accuracy goal. Even with the 2m best case, that is a lateral accuracy of 6.5 feel, or clear in another lane. However, the cameras should be able to tell if you are in a middle lane, or a left edge/right edge one... and therefore, they should be able to decide to move to the left or right as needed for the exit.
- The information about if an exit is a left or right exit, and how many lanes there are are available is normally in the GPS database, as well as advertised with lane markers and street signs, if the roads follow the NHTSA rules *(in the US) this should work for the majority of cases. (limiting this to talking about highways now). So, if the car knows that an exit is coming up on the left, it can start moving left at least x minutes early, with x defined based on traffic.
- In terms of the problems with decisions like AP1 has... well, we will have to see... this has 3 more cameras than AP1 did (active at least in the EAP option set), along with better ultrasonic sensors, so I suspect that it will be able to do much better at navigating lanes, and I would not be surprised if there were more cases of missed exits, closer calls, etc... but again, the owners will have to learn right along with the car, what works, what doesn't.
- I think that the places that are most likely to cause problems are roads that are ones that some might call highways, others would not. Divided, limited access, interstate roads will probably work really well, but when you get off of those to state highways, some are going to say they are freeways and the system should work perfectly there, and on some of them, it will, on others, especially ones without well marked lanes and exists, there will be problems.
2. Exit freeway and hand nav back to driver:
- You are correct in identifying this as a challenge. I don't know how this will work, nor does anyone else other than Tesla engineers at this point. However, just because you and I don't know how it will work, doesn't mean it is impossible. In the end, I suspect it will start poking at the driver a few miles prior to the exit, and if it does not get some kind of answer (holding the wheel, pressing an "accept" button, whatever), it will decide to do "something". Personally, I would expect it to simply exit as planned and pull over at the next available place to pull over (shoulder, parking lot, whatever. not an ideal situation, but better than just letting the car crash after exiting. It could even work exactly as the Volvo system you mentioned.
- Remember that these cars have ALL of the full self driving hardware on-board, so it is certainly possible for Tesla to decide that in an emergency, the car should utilize everything to safely drive in town until it can find a place to pull over... it could even call 911 at that point if needed.
3. Smart Summon:
- the definition of "smart summon" (from their web site) is "With Smart Summon, your car will navigate more complex environments and parking spaces, maneuvering around objects as necessary to come find you." and from the sales page; "self park when near a parking spot and be summoned to and from your garage."... nothing here talks about parking lots and the "complex environments" could be simply a garage with a curved driveway (see the picture)... my read of this means that I can get out of the car when it is in the lane next to an open spot and walk away and it will park itself (AP1 can basically do that already). and that I can summon it from my garage even it it has to turn to get in / out and get to the door. If the driveway is near a busy street, it will be up to the owner to know its limits (as it is today for many features). I don't take this to mean it will drop me off at the door of the mall and wonder off to find a spot.
4. TLDR:
- I suspect that FSDC is pretty close to being able to do 90% of what it needs to do, they are now working on that last hard 10%. Then their real job starts, trying to convince all of the various rule making bodies around the world that it is safe to be on their streets. What this means is that I think they are already at an advanced stage that will be able to use pieces of it in the EAP (AP2) stuff.
- Having Telsa's map highways helps, but (at least on highways), the cameras that do exist should be able to figure out where exists are and how to handle them...We cant really tell if adding cameras or other sensors is needed for safety until we know more about the systems. Sure, more cameras are good, but are they needed? No way of telling at this point.
Finally, in terms of the cameras, I would not be surprised if they stop talking about the numbers of cameras in each option, and instead just start talking about what each option can do. In the end, if having 4 cameras is all that is needed to drive safely on highways, fine, but I hope that if they determine that 5 cameras are needed (or 8), they will just start using those other cameras (again, they all exist, so its simply a matter of updating the software). I don't see the part of the description anymore that talks about which cameras are live for EAP and which ones are added for FSDC
