EU finalize and deliveries
Croatia,
Delivery date states Nov 30 - Dec 7.
I have 1 question, ordering 3 phase power outlet on my parking space. What is maximum charge speed for Plaid, 11,5 kW or 16 kW? Difference in installation is significant. Thanks.
I use this calculator :
in Summary, it also depends on the amperage (16 or 32 Amps)
so 11.5Kw compared to 16Kw, the difference will be the speed of charge which is 40% faster. so if charging time for (32Amps, 240Volts, 16Kw) is 5 hours, then you (11.5Kw) will take you 7 hours to fully charge your car.
in my opinion, if you make the habit of charging every night and you don't take very long commutes every day, then 11.5Kw should be good enough, unless the difference in installation is not significant.
Again this is just with my limited knowledge of electricity, so better to get more opinions from experts.
It seems like it is 11,5 kw
It is very hard to find real information, somewhere it states 16 somewhere 11,5.
11,5 kW is 2550 EUR, 16 kW is 3600 EUR. It's waste of money if Plaid can charge only 11,5 kW. Hopefully someone has correct info
Croatia,
I have 3 phase, 16amps, 240V and it charges at between 10 to 11kw which is enough for overnight charging. For 32amps you will need a type 2 installation which is expensive and it will give you only 5kw extra
Hello everyone!
Plaid ordered on february 2021, from Italy.
Got a call from a SA more than one month ago asking if I was confirming everything in the order (obviously, I confirmed everything!)
I still have got a reservation number on my account page, with a standard "dec 2022-feb 2023" delivery indication.
Digging on the code of the page, I can see my VIN: 5YJXCAE4XGF0068xx
Is it a standard VIN? 2023 my car?
Reactions: lsds
Hello everyone!
R u sure about the “G”? It should be N for 2022, or P for 2023. For the best of my knowledge at least:)
So the ships to europe should be
Reactions: fakerlind
Here you can check if your car is on that vessel
My car on that ship!
Model S Plaid
Put your VIN inside and check
