Anyone here use EVGo chargers regularly? We're about to go on a roadtrip with a trailer and are looking at filling the SC gaps with alternative chargers.
From The EVGo Website...
EVgo EV Charging Resources| What is Electric Vehicle Charging
FAST CHARGING ETIQUETTE...
2. Make sure your vehicle is less than 50% at charge level.
and
7. Note that if you do not need to charge that long, you should leave earlier to accommodate other EV drivers. Your vehicle will charge at a lower kWh if it is above 50%. It will not use the kWh fast charging capability, but will charge at a Level 2.
So if I'm part way through the mountains and are pretty sure we'll need to be at 85% to make it to the next SC, and get to this charger with 55%, so need about 25 kwh added it will only charge at level 2? Really?
30 minute boost is needed, but as they say they limit to Level 2 above 50% we would need to sit for a few hours?
Anyone run into this before?
I've sent them an email to confirm, haven't heard back yet.
Thanks,
NB
and
Thanks,
NB
