I had purchased the one similar to that and modified it to be like this one. The one you linked would work I believe, but might run into the same issues with the connector on the blue side, I had purchased this one
https://www.amazon.com/dp/B07QJCFKK6?psc=1&ref=ppx_yo2ov_dt_b_product_details and it didn't work because the blue end is to deep for the factory radio connector. If you have the ability to crimp your own like I do though you can just modify the ends. The color in fakra matters and I believe white should go with a white receptacle and blue with blue etc, similar to how the sirius one is curry as the color. If you are good with soldering/ crimping, you could just modify the factory harness too, but I wanted to be able to revert my connection should tesla ever try to pull the plug on the x tuner being supported. Finding the right harness seems to be tricky though and amazon mostly has ones for European cars such as bmw. Tesla seems to have used an uncommon fakra connector that's mostly used for lte antennas and gps. Most the cars I have done stereo mods on use the pink or blue fakra for fm.
