andydoty
I too had the charging amperage cut in half. You'll find that if you set your amperage to anything above 40 it will cut in half (master charger maximum perhaps). If you set you amperage at 40, you should charge at 40A. Anything above will result in 1/2 of the amperage setpoint. Anything below will result in charging at that limit.
