Firmware 7.1
Discussion in 'Model S' started by NOLA_Mike, Jan 9, 2016.
  1. msnow
    msnow Active Member
    SoCal
    Are you talking about the Google Maps copyright? If so that's not the same as the Navigon maps update date which, as far as I know, is not visible to users like us.
  2. hiroshiy
    hiroshiy Supporting Member
    Tokyo, Japan
    Hi, @dirkhh, I already entered firmware update to your app, and I'm from Asia (Japan). I got and installed the update on 25th.
  3. MyJoule
    MyJoule Member
    Tucson, Az
    #1643 MyJoule, Feb 28, 2016
    I just confirmed that both my "classic" with dual chargers and my autopilot with dual chargers equipped cars indeed do not enable the second charger after installing the latest update. (2.12.126) I called Tesla motors technical support and they pulled the log from my autopilot car and could see indeed it was only using one charger even though it should have been using two. They said the service center will contact me tomorrow, I suspect we'll see an OTA update pretty quickly to fix this issue. I wonder how this one slipped by Software QA?
  4. smartypnz
    smartypnz Supporting Member
    Monterey Peninsula
    #1644 smartypnz, Feb 28, 2016
    Funny, mine installed itself before I went to check on it after getting notification that an update was available. Thought it was perhaps another 'no choice' update.
    Vers 2.12.126
  5. NOLA_Mike
    NOLA_Mike Grouchy
    Hammond, LA
    Curious - is everyone with dual chargers having the problem or is it just a few of us?
  6. BertL
    BertL Active Member
    Carlsbad, CA
    My charging normally starts at 12AM and ends before I wake up each morning, so I have not paid attention to it. Just went out and manually initiated a charge after running errands. My S90D running 7.1 2.12.126 (since 2/26) with dual chargers and an 80A HPWC is also maxing out at 40A during a charge, even though the maximum available is still showing 80A. I have consistently seen charging as high as 79-80A for months before this after replacing a defective HPWC early on. I'll get a note off to [email protected] after this post to chime in with my problem as well.
  7. wk057
    wk057 Senior Tinkerer
    Hickory, NC, USA
    I'm on 2.12.126 now and currently charging at 80A, so, seems to not be everyone.
    Did you update from 2.9.x or 2.12.22 to 2.12.126? 2.12.45 is where the last charger firmware update came into play, so, if you had 2.12.45 already and didn't have the issue then, I'd be pretty confused.
  8. BertL
    BertL Active Member
    Carlsbad, CA
    FWIW my S90D was on 2.9.154 working fine with dual chargers at 80A before my update on the 26th. It seems to be limited to a single charger since moving to 2.12.126, and would be awful coincidental if several of us started having a hardware failure about the time of new firmware being introduced. I wonder if this has something to do firmware specific to Gen1 vs Gen2 Chargers? I was told I have Gen2 in my S90D.
  9. NOLA_Mike
    NOLA_Mike Grouchy
    Hammond, LA
    I went from 2.9.154 -> 2.12.126
    How about the P85 (wife's) - is it okay too?
  10. wk057
    Hickory, NC, USA
    Appears to be, yeah. She went from 2.9.154 to 2.12.126. She has gen1 chargers, my P85D has gen2. Both seem fine.
    The charger firmware was in fact changed in 2.12.45 (so a jump from 2.9.154 to 2.12.126 would have included it). Not sure what changed, but it's definitely conceivable that something got botched for some people.
  11. MrClown
    MrClown Autosteer Beta Tester
    Denver
    Mine went from 2.12.22 to 2.12.126 and I had the problem in both. I was hoping the update to .126 would fix it. I have an appt with service this week for the problem but I wonder if I should cancel it since it'll likely just be a firmware fix anyway.
    Edit: the previous firmware I had (2.9.154) did not have this issue.
  12. wk057
    Hickory, NC, USA
    Those of you having the issue... maybe convince your service center or someone else to try a redeploy of your firmware? This would reflash any modules (charger included) that didn't take the latest update, and might fix the issue. Not sure if the service centers can do this remotely, although technically the ability to do so by Tesla is there.
  13. msnow
    msnow Active Member
    SoCal
    Whether it's a messed up module, bug or deployment issue or something else I saw some people in the Tesla Motors forum posting about the same issue.
  14. Cyclone
    Cyclone Cyclonic Member ((.oO))
    Charlotte, NC
    I haven't had the opportunity to test my dual chargers at 2.12.45. But given the reports, I have not installed the software update pending on my car (got it the first day of 2.12.126 reports, so likely that). I may have to swing by the service center just to try it out and make sure they are still enabled on my car.
  15. modelx007
    modelx007 Member
    boca raton, fl
    The update fixes the hump my entrance to garage has where before it wouldn't proceed. Now it enters without an issue.
  16. BertL
    BertL Active Member
    Carlsbad, CA
    I received a reply email from Tech Support in just 2 hours ... problem has been opened with my local SC and I should be hearing from them soon (I suspect tomorrow, as they are closed on Sunday). I'll post back if I come up with new news should someone else not report back here first.
  17. AWDtsla
    AWDtsla Active Member
    NE
    Looks like the new summon doesn't support parking tail-in. The distance setting won't work in this case :-/
  18. dirkhh
    dirkhh Middle-aged Member
    Portland, OR, USA
    That's much appreciated!
    I know that the same has been done in Norwegian forums in the past. Still, not a single report from Norway, UK, Germany. Very odd.
    - - - Updated - - -
    Thanks - I see that you specify Japan in the Notes section, but that isn't taken into account in the statistics. Could you update your country?
    On the tracker, click on Home, then on the little pencil after the description of your car. That opens a new window where you can update the car data, including the country :)
    Thanks
  19. wk057
    Hickory, NC, USA
    I'm pretty sure 2.12.45 -> 2.12.126 doesn't update anything with the chargers, so, if you already have .45 you're not going to hurt anything. Worst case, if your charger didn't take the update before it'll try to redeploy to it when it sees it isn't up to date.
  20. Veggen
    Veggen Member
    I have seen a couple of 2.12.126 reports on the norwegian forum.
    Also put in a request for people to update the tracker, hope that helps.
