Did my first track day with the P3D today. Had a great day, the car did great on track! Definitely needs a driver mod.
Made it through 4x 20 min sessions, lots of running around to charge up. For anyone who's interested, my day went as follows:
Left home at 100%, arrived at track at 88% battery
Charge from 88 to 97% before first session (using 14-50 outlet on site).
First session used 40%, ending at 57%
Charged to 70% before 2nd session
Second session ran down to 30%
Went to supercharger at the Biltmore over 2.5 hour lunch break, arrived at 20% and departed at 97%
Arrive back at track at 88%
3rd session ran down to 40%
Charged back up to 50% before 4th session
Ran down to 6% at end of 4th session
Had to charge for 30-40 mins at the end to make it back home.
Not sure if it was the heat (high of 92 today) or what, but battery usage was higher than I was expecting. Acceleration dropped off significantly as battery depleted. I went from basically passing everyone early on to running about in the middle of the field and pointing a handful of people by near the end.
Brakes are a problem. I added stainless lines and Castrol SRF fluid before going out. The pedal was nice and firm over the past week on normal street driving, but got really soft halfway through the first session and stayed that way the rest of the day. The bleeder valves on the front calipers started seeping fluid, and continued even after I tightened them up. No idea what's going on here, other than maybe the calipers heated up so much that the bleeder valve threads loosened up? Any ideas on this one? Brakes are still extremely soft after cooling down, going to flush them again tomorrow and see what happens. Have RB Performance XT910 pads on order, but the rears are holding things up so I had to run on stock pads today.
I dropped the driver's side tires off track in my second session and corded both of them...that was expensive.
Overall, had a great time and got tons of positive compliments on the car. I got passed by one person the entire day (DE3 instructor BTW), until I got below 10% SOC with soft brakes...then started doing a couple of point-bys. Can't wait for the next one!
