With all due respect to the above, I think a replacement screen is the way forward, because:
From the sounds of it you may need to file a small claims to get them to pay. Hopefully it doesn’t come to that.
- There’s no reason to assume that a replacement screen, fitted by Tesla, will be any worse or better in fitment than the factory screen. This is Tesla remember.
- You’ll have a warranty on the glass in line with the car. If you’re not happy with the fit you can complain about it.
- Access to the affected area is very limited, and the job of trying to expose the copper and apply solder very fiddly. Who is going to take that job on with confidence? Certainly not the tinters, who I wouldn’t trust to fit a cup holder rubber liner at this point, so who?
- What risk is there of additional damage being done to surrounding areas from attempting to solder etc in such a tight space. I’d suggest it’s quite high risk.
- The aforementioned power problem. Can you fully isolate it on a Tesla?
- How robust and long lasting is this fix going to be? Is it going to be as resilient in different weather conditions?
- Sticking bits of foam on to fix the brake light bleed.. really?
- Some early M3s are exhibiting spontaneous pressure cracks in the rear screen, replacing the screen resolves that.
- Early M3s don’t have the lip seal around the bottom to deflect water away from going in to the boot, this resolves that too.
