Nintendo80
Thank you both guys. I’m dealing with RCM2_a124. It comes and goes as he feel and same story they have no idea. I will give a shot thanks for the suggestion.
Bad news. The RCM2_a052 error popped up again yesterday. It went away after a minute so not worth opening a ticket.Last year there were no details on the invoice. When I asked what they fixed their response was "It was from a loose ground connector that was causing the issue. We installed a new ground and it was working as it should" - nothing specific.
That wasn't the end of it as the RCM2_a052 error came back a couple of months ago. This time they replaced the Steering Column Control Module. Fixed for now.
And today it came back along with RCM2_a064. I scheduled service.Bad news. The RCM2_a052 error popped up again yesterday. It went away after a minute so not worth opening a ticket.
Yup me too going to look for that ground and clean it to see if it fixes itI just Kick the area that @Proppilot indicated and my RCM2_a124 goes away… every time it comes back just kick it, WTF!!!
Blue Stuff. My MSLR is MF442 and my car took the cake for SRS faults. They replaced EVERY airbag (some twice I believe) and controller(s) and in the end....after even they were embarrassed, upper management in Tesla made them replace driver and passenger side wiring harnesses. They found a crimp in one of the harnesses which was creating an impedance error a false reporting. The good news is that the problems are LONG gone but the bad news was that they had to pull out all of the trim and did a crap job smacking everything back together so the car has rattles and creaks that I am systemically tracking down and eliminating (and finding things like an airbag without the velcro restraint fastened around it) etc. If you are having ongoing issues that they cannot resolve, consider pushing them to escalate this to Factory Engineering and pursue a harness swap out. My learning coming out the back end is if they cannot fix things by replacing parts, it was the wiring and as our cars are in the same build batch (I got mine just under three weeks after you did) then this may be your issue. My car went in 14 times for SRS errors and they were beside themselves unable to properly fix it.....My saga continues. The instrument panel harness was replaced but the alert came back a few days later. Now they have fixed ground G660 (driver door pillar mentioned above) which supposedly was looked at before. (Maybe they are reading this thread?) I'm hoping this is done.
I feel sorry that the whole thing you have gone through, the whole situation you spent time on. Hope they could compensate your time to&from them also since that’s their fault.Blue Stuff. My MSLR is MF442 and my car took the cake for SRS faults. They replaced EVERY airbag (some twice I believe) and controller(s) and in the end....after even they were embarrassed, upper management in Tesla made them replace driver and passenger side wiring harnesses. They found a crimp in one of the harnesses which was creating an impedance error a false reporting. The good news is that the problems are LONG gone but the bad news was that they had to pull out all of the trim and did a crap job smacking everything back together so the car has rattles and creaks that I am systemically tracking down and eliminating (and finding things like an airbag without the velcro restraint fastened around it) etc. If you are having ongoing issues that they cannot resolve, consider pushing them to escalate this to Factory Engineering and pursue a harness swap out. My learning coming out the back end is if they cannot fix things by replacing parts, it was the wiring and as our cars are in the same build batch (I got mine just under three weeks after you did) then this may be your issue. My car went in 14 times for SRS errors and they were beside themselves unable to properly fix it.....
