I added 'custom' colors to the table that match the picture. I used this online tool to get the HTML/HEX code which I used in Google Sheets. HTHGreat eye. My original source was wrong so I checked a couple of others. I think the below is more correct now.
I added this in case more are needed: 'Via: TMC scottf200 | v2 | 24-Dec-2020 1:00am'
Are those Waymo cars getting gulped?
#FSDBeta 7 2020.48.10.1
This is a video trying to show what is visible on unprotected left turns from the B Pillar camera. I have mounted a GoPro externally trying to show both views at the same time.
1:55
Based on Tesla's Model Y picture for the B Pillar camera. Here's my attempt to show the intersection at 80m range
Great information in Chucks original video and in the two posts above. This is going deep into the weeds but I'd be curious to know what speed the Tesla would have to go to get to a safe spot just before completing the left turn (as shown by the green X). Here is the question rephrased: Per the @scottf200 chart above using the B pillar maximum distance the Tesla has between 2.9 and 3.3 seconds with cross traffic at 60 or 50 MPH to get to the 'safe spot' (distance needs to be calculated @Dan D.I added 'custom' colors to the table that match the picture. I used this online tool to get the HTML/HEX code which I used in Google Sheets. HTH
https://imagecolorpicker.com/en/
Great information in Chucks original video and in the two posts above. This is going deep into the weeds but I'd be curious to know what speed the Tesla would have to go to get to a safe spot just before completing the left turn (as shown by the green X). Here is the question rephrased: Per the @scottf200 chart above using the B pillar maximum distance the Tesla has between 2.9 and 3.3 seconds with cross traffic at 60 or 50 MPH to get to the 'safe spot' (distance needs to be calculated @Dan D.). With that available time what average speed does the Tesla have to go to reach the safe spot.
Here is why I ask: If the Tesla has to average 50 MPH for that short distance it simply won't happen. If it only has to go 10 MPH that leaves a good cushion to get there safely at say 20MPH +/- average (allowing for accel/decel).
Distance is ~21.6m = ~70.9ft
Assume constant acceleration at 2.9/2 seconds then constant deceleration at 2.9/2 seconds to make it simple.
Speed from rest to 70.9/2 ft in 2.9/2 seconds is 48.9 ft/s == 33.3mph
Acceleration from rest to 33.3mph in 1.45 seconds is 0.72g
Any errors please let me know.
Fantastic...thanks. Any opinion from you or anyone whether 0.72g is reasonable?
Some people like a roller coaster ride, some don't.Fantastic...thanks. Any opinion from you or anyone whether 0.72g is reasonable?
I agree that FSD would probably not be that aggressive. That would seem to make this a true problem intersection for a left turn.If we use a Model Y maximum acceleration of 0-60mph in 4.8s, that's ~0.57g. Assume acceleration is roughly linear over that range. 0-33mph would also be 0.57g
Other models have faster 0-60 times. Not sure how aggressive FSD would be, probably a significantly lower amount than full out acceleration.
Too high.
Of course, 60 mph cross traffic is uncommon - and where it is common (rural areas), traffic is low.
What happens after 80m ?That stretch of road has a 45mph limit. Of course it's the speeding cars that are gonna hurt the most. Crossing highways is worse, even if it has an unobstructed view the B pillar camera still has a listed 80m range.
The car would have to learn to recognize such crossings and try a different route.I agree that FSD would probably not be that aggressive. That would seem to make this a true problem intersection for a left turn.
Uncommon may depend on where you live. I was surprised to until they Joshua Brown (RIP) incident (and a TM3 one later) that there are many highways that have entry points like that (Yes, I know JB was on the highway and the truck entered from 90 degree in this example). Imagine a Tesla FSD car needing to get on the highway from a 90 degree stopsign entry point. Tesla Autopilot fatal crash with truck is under investigation, preliminary report released - Electrek... Of course, 60 mph cross traffic is uncommon - and where it is common (rural areas), traffic is low.
Really great question since without understanding how objects further away then 80 meters can or cannot be handled by FSD determines how we view the problem.What happens after 80m ?
We can't clearly make out much at a distance, but we can guess a car is coming ...
