FSD saved us from being crushed by a semi
Discussion in 'Autopilot & Autonomous/FSD' started by scottiev, Jun 29, 2020.
  1. scottiev
    scottiev Member
    New York
    I drive AP at full attention to the road. And should have been more wary of this truck, for sure.To your point, I don't think we would have made it out by punching it once the truck started to move over.
    When the truck began to encroach my foot moved to the brake, which already engaged fully engaged - assuming by AP, maybe just AEB? We went from about 75 to 30mph in less than a second. One hand went to the horn, and the other to try to split the difference between the concrete and the truck. AP dialed it so quick and so precisely, I didn't have anything better to add to the control. That's my memory.
    I wish I had been more cautious around this truck. I assumed we were within his sight lines because we were overtaking from 100+ ft behind. Did not see the useless mirrors on the truck, or lack of signaling. I did not appreciate this driver's stupidity.
    • Like x 8
    • Informative x 3
  2. cucubits
    cucubits Active Member
    TX
    It's not about hindsight. It's about some people putting too much trust in current AP capabilities. Right now it saved you but that doesn't mean by a long shot that it can be trusted in any hairy situations. You got lucky but you can't say that without AP you'd have been off worse. Most likely you'd have been paying more attention to surroundings and get away from the semi way before he actually made his mistake.
    • Disagree x 12
  3. Feathermerchan
    Euless, Tx
    Did you take the video private? It says so now.
  4. Az_Rael
    Az_Rael Supporting Member
    Palmdale, CA
    Ahh, good point. So AP essentially made the decision to slow vs speed up before you could react, so at that point you are committed. Plus you had less room to make it out the front (although the driver MIGHT have spotted you and swerved, but no guarantees they were even looking at the road driving like that.)
    Glad you had to opportunity to be just angry with him for his terrible driving vs the alternative.
    • Like x 4
  5. powertoold
    powertoold Active Member
    OP wasn't cruising along a semi. The semi literally encroached on the OPs lane from 2 lanes away. Most people wouldn't avoid a semi at the instant it comes next to them.
    As for your thoughts on accidents and "paying attention," way to be captain obvious. Most accidents are obvious in hindsight. That's why they're accidents.
    • Like x 9
  6. bons
    bons Bonifus
    Hong Kong
    Report the driver and company
    • Like x 4
  7. scottiev
    scottiev Member
    New York
    I was getting trolled by some people who claimed to be relatives of the (now out of work) truck driver.
    Here's a new link to the video:
    • Like x 9
  8. scottiev
    scottiev Member
    New York
    Maybe. But if I had been in full control, I don't think I could have been on the brake fast enough, and I really don't think I could have escaped the tunnel cleanly without bouncing off either the concrete divider, the truck, or both.
    Also, data point: I've been driving for 26 years and have never been involved in an accident. Knock on wood.
    • Like x 13
  9. Jerryt175
    Jerryt175 Member
    Libertville
    I'm having the opposite effect. I'm having ghost braking when using cruise control. Today i was going 75 and it slammed on the brakes until I took over at 30 on the highway. Thank GOD no one was behind me as I would have been killed. Everything in my car was in the front or on the windshield. Horrible.
  10. Seabreeze2112
    Seabreeze2112 New Member
    west babylon
    I drive a truck on that same stretch of 95 by Meadowlands weekly.... both of then trucks should had been getting out of the left lane at that point before 280..
    Also that was a short container....but closer to 60,000 lbs..not 30
    • Informative x 3
    • Helpful x 2
  11. M_D129
    M_D129 Member
    Minnesota
    Unfortunately, this won’t be anything you see in mainstream media if any kind. Just the bad stuff, or issues they used to have that they already solved, but are still coming up.
    I just read an article recently about the issues with the battery packs on 2012 Model S..8 years later, and they’re still talking about that. And the occasional video of someone railing into a semi while not paying any attention.
  12. TLLMRRJ
    TLLMRRJ Active Member
    Houston
    #32 TLLMRRJ, Jul 1, 2020
    When I worked as an engineer on the oil rigs in Africa, it was tough job because a lot of equipment failed, there was huge pressure to get the job done and done right, and there was little by way of backup equipment.
    Lots of fellow engineers would be applauded for saving the day when they got into a bind. I didn't have too many of those atta-boys because I was more prepared than everyone else and avoided getting into binds (I spent more time inventorying my equipment, learning about the equipment inside and out, pre-checking and double-checking equipment, making sure items didn't get damaged in shipping to the rigs, etc).
    AP didn't save your life, it almost killed you.
    And this is the big problem with any self driving aids like AP. AP doesn't know, and will never know, how to drive defensively. It was just keeping a fixed distance from the car in front, and you never should have been there. You got lucky that AP was able to help get you out the bind it put you in for this scenario. Here in Houston, those barriers are rarely lined up properly, and I really doubt AP could have handled one the barriers jutting out. Being lucky that AP didn't happen to kill me is not a win in my book.
    • Disagree x 16
    • Like x 4
  13. 2280
    2280 New Member
    And I thought the biggest risk from Chiquita was slipping on a banana peel.
    • Funny x 2
  14. Mr. Jim
    Mr. Jim Member
    Santa Barbara
    Can you read his plate to give with the video of this idiots driving habits?
  15. Pomato
    Pomato Member
    Alpharetta
    I'm glad that truck driver is out of work.
    Next time don't stay on the side of a semi where it would be difficult to see you like that. Estimated 30%+ of accidents are due to sleep deprivation and truckers are more commonly sleep deprived. One accident and you're likely dead. You were both in the wrong.
    • Disagree x 2
  16. Jimmy.J
    Jimmy.J New Member
    Denver, CO
  17. ChickenDipper
    ChickenDipper Member
    Derby, UK
    Which is well within the realms of AI and we’re decades away from having that in cars.
  18. Xcelerator
    Xcelerator Member
    Dallas
    Incorrect. Under 23 CFR § 658.17, an 18 wheeler's max weight is 80,000 pounds
  19. The_Observer
    The_Observer Member
    Los Angeles
    In New York, semis can go on the left lane?
  20. jackbowers
    jackbowers Jack Bowers
    Having logged over 350,000 Tesla miles over the last 11 years, I've been in situations like that several times, and in recent years I've encountered some truckers who see a Tesla coming and pretend like they are moving into your lane to trigger an Autopilot response. As such, if I am next to the cab (ahead of the trailer), I accelerate hard to get out of the way, over-riding Autopilot if necessary. While this is not advisable in an ICE car because of throttle lag and slower acceleration, it is the fastest way to get out of danger in a Tesla, and I consider it the safest maneuver for drivers who are consistently generous with following distance (as Autopilot is).
    • Like x 4
