Note, he said _Original_ Roadster HPC. They changed designs along the way...Interesting... Don't own a Roadster. Its HPC includes both a smoke detector and temperature sensor (thermister) shut off?...
The original Roadster HPC was built by Tesla and had a bunch of safety interlocks. There was a separate smoke detector that went on the ceiling with a thin signal wire that connected to the HPC. If the smoke detector smelled smoke, the relays in the HPC would open and charging would stop. There also was a tension detector on the cable... so if the cable got tugged charging would also stop. Off the top of my head I don't remember if there was a thermal interlock on the Roadster HPC, but there was talk of putting a temperature sensor in the UMC plug.Interesting... Don't own a Roadster. Its HPC includes both a smoke detector and temperature sensor (thermister) shut off?
I think that a simple thermistor in the plug of any EVSE (if it's a portable/plug-in unit at the unit's plug) and in the plug that plugs into the car would be more than sufficient to avoid the vast majority of these issues.With so many EVs out there now, it's probably an idea worth revisiting.
At the time of the introduction of the Roadster, EVs were in a fragile state. The then CEO said that one garage fire while charging could kill the electric car, again, perhaps permanently. So a lot of thought went into that sort of thing.
Practically though, the interlocks in the HPC would trip when they weren't supposed to and were often defeated just to get the HPC to work. Clipper Creek had been making these things for years without such interlocks and Tesla ended up just contracting them to make the Roadster HPCs.
The Roadster UMC sold by Tesla wasn't available till quite a while after the first Roadsters started shipping and that thermister in the plug idea may not have made it. I think the first RFMCs had it, though.
Yes we should pay attention to electrical wiring... but garage fires are not unique to electric vehicles. There are plenty of fire risks with ICE vehicles, including:
Honda recalls Fit for fire risk, says park it outside
I think split panels doesn't meet code now. But back in 1980 when my house was built, the code in my area was "<= 6 breaker throws to cut off entire panel power". I think today's panels all have a single main cut off.
Anyhow, back to my original question, other than my 70A split panel breaker which is really just cut off switch for the smaller feeds. 50A breaker is the biggest amp feed in my panel. Oven, furnace and everything else is lower amps at 30A.
So the Tesla charger is drawing 40A for say 4 hours at night while we are sleeping and parked in the garage IS the highest current flow in the house. This doesn't automatically make it unsafe of course but just noting it is one of the highest if not the highest current draw for extended time periods.
i installed a smoke detector that is internet connected plus larm service in the garage. plus a big fire extinguisher close tomthe garage. long before this. just did feel right as something big charging in the garage it feels better. not the car I dont trust rather the electrical installation.![]()
http://news.yahoo.com/exclusive-tes...tem-may-started-garage-235501912--sector.html
fire department says something and tesla says something else...
"The most probable cause of this fire is a high resistance connection at the wall socket or the Universal Mobile Connector from the Tesla charging system" which was plugged into a 240-volt wall socket, the report said.
Moderator note: Changed the thread title to be slightly less *inflammatory*.![]()
Exactly.If you read Tesla's response to this incident, they are very careful to say that nothing happened on the car side of things and that the fire started at the connection point with the wall outlet. Tesla is very selective in its language. For all we know, a bad UMC plug could have started this fire and Tesla is simply steering the conversation back towards the car. The fact that the fire department could not rule out the car's charging equipment tells me that it very well could have been the UMC. After all, we've had several owners share stories and photos of melted UMC plugs. Put that heat near a bunch of cardboard boxes and you have the conditions for a garage fire...
Some cardboard boxes stacked near the point of connection between the Tesla Model S charging system and the connection to the 240-volt outlet helped the fire spread, the report said.
