HankLloydRight
No Roads
If you only need hot water at that location at those times, then the water heater is superfluous.
First, folks, take a look at this article which explains my (common) situation:
http://www.chandlerdesignbuild.com/files/fhbDecJan08.pdf
The purpose of the 10 gallon aux tank is to buffer the cold water slug left behind in the tankless heater upon start-up.
In a world of free energy, I'd run the aux heater and the circ-pump 24x7. The aux heater alone draws a constant 2000w when the circ pump is running.
We just moved into this house, and got the first few electric bills over $500, I had to figure out what was going on. The first problem I found was that one zone of the HVAC was somehow switched to A/C and the others to heat. So in the middle of winter, the A/C was running to compete with the heater. Easy fix (we think the home inspector left it on A/C and we just didn't notice it. The house wasn't cold). But that didn't change our bill much the following month. I tracked the huge culprit down to the circ pump and the aux water heater. Actually, here's a graph of the energy usage before I put the circ pump on a timer:
Do you have the circ pump for when you will have large water demands, and the small tank for the rest of the time? If so, the new setup will only have the small heater on part of the time and the water will get colder in the intervening periods, more so as hit water is pulled from the tank.
So the bottom line is that we only need "instant" hot water upstairs in the morning for showers, and a few hours in the evening when my wife likes to take a bath (Coincidentally, we have the bathroom tile floor heater on the same schedule. ).
The circ pump and the aux heater work together. If the aux heater isn't on, the circ pump circulates cold water. If the circ pump isn't running, the heater keeps its tank at the set temp of 130 degrees but it doesn't circulate (which was causing my most recent problem with the 2kW spikes).
So simply tying the heater switch to the circ-pump timer with the relay should fix the problem and deliver hot water when/where needed based on the one timer, and not run the aux tank the rest of the day at all. This will kill the 2kW spikes I was seeing. That means if someone needs hot water outside of when the aux tank/circ pump are on, there's a short delay as hot water from the instant-on tankless heater gets up to the faucet.
I thought hard about getting Sense, but figured I could figure it out myself and save the $300 (I already have a two CT energy monitoring system from Efergy that works really well). I also don't like how they require you to install a 240 double breaker to power the device and detect actual voltages. I for one don't have any free space in my panel or subpanel. It would be nice if there were an alternate option. Anyway, I've knocked out most of the problems, so I'm not sure I need to spend the $300 for it anyway.
