Getting TACC to follow the speed limit
Discussion in 'Model S: User Interface' started by Joehunk, Jun 11, 2015.
  1. Joehunk
    Joehunk New Member
    Austin, TX
    Is there a way to get TACC to automatically adjust speed according to the speed limit? I just got the car, and a hash mark will appear around the speedo that matches the speed limit, but the cruise control does not auto set to that speed. I have to pull and hold the cruise control stalk to set it to that speed, which is a bummer if the speed limit suddenly drops.
  2. Todd Burch
    Todd Burch Voltage makes me tingle.
    Smithfield, VA
    It's supposedly coming, likely in the next update. They demoed this back at the D reveal event.
  3. rickgt
    rickgt Enthusiast owner/member
    Carmel
    Interesting idea to auto adjust. BUT, I have seen cases where the speed limit sign is misread (truck speed, or school zone when not in session)... if it automatically adjusted, it might cause problems for the cars behind you.
  4. iadbound
    iadbound Member
    No. VA
    I hope nobody is using TACC in a school zone!
  5. Saghost
    Saghost Well-Known Member
    Delaware
    Not just an idea - this was a promised piece of the Autopilot package, and was demonstrated in the reveal event last October. I'm sure it is coming... sometime...
  6. mikeash
    mikeash Active Member
    Fairfax, VA, USA
    One place I routinely see problems is on a highway near my house with express lanes. The normal part of the highway is limited to 55, and the express lanes are divided by plastic poles and have a limit of 65. The car doesn't realize that the signs on the left side only apply to the left two lanes, and the signs on the right side only apply to the right four lanes, so it tends to wobble back and forth between 55 and 65.
  7. Patrick W
    Patrick W Active Member
    SLC, UT
    Real world example is I-80 westbound passing SLC International airport. Speed limit is 70 in that area but there is a frontage road that runs parallel to the freeway. Speed on the frontage road is 50. Every time I drive by there on I-80 my car reads the 50 sign for the frontage road and the indicator on the dash quickly drops from 70 to 50.
    I've joked with some folks that once the new system is operational someone could construct a sign reading "10" that looks like the real thing. They'd then put that next to the freeway and wait for a Tesla to drive by... :)
  8. Cyclone
    Cyclone Cyclonic Member ((.oO))
    Charlotte, NC
    One would really hope for two things when auto-adjust comes to light:
    1 - when adjusting speed, do so somewhat gradually. TACC can sometimes be harsh in adjusting to cars moving into/out of your lane and speed adjustments should be calmer than that
    2 - hopefully the car will only auto-adjust up to 15 mph at a time. Any greater change and hopefully it with prompt the driver for input
    3 - yeah, a # 3! Hopefully there will be an option NOT to auto-adjust, for the I-80 and Fairfax, VA people.
  9. Todd Burch
    Smithfield, VA
    Just as TACC has improved, I'm sure the speed limit recognition will be improved as well before it comes to our cars...and from what I've heard the camera can distinguish between regular speed limit signs and school zone signs...so that should be handled as well.
    But as with anything else, you will need to monitor and adjust as necessary.
  10. wayner
    wayner Active Member
    Toronto
    Why not in non-school hours? The signs are still there showing the reduced speeds but don't apply when school is out, at least not where I live.
  11. green1
    green1 Active Member
    Calgary, Alberta, Canada
    Maybe because TACC is explicitly listed as not for use on surface streets?
  12. Majerus
    Majerus Member
    Illinois
    Maybe cross reference the signs with GPS data resolves this issue?
  13. anxman
    anxman Member
    san francisco, ca
    I'd like some sort of notification to indicate that the speed limit has changed and then I can adjust accordingly. I've had issues recently where the car thinks the speed limit is much higher than actual.
