GM Chevy Volt
dpeilow
Moderator
May 23, 2008
9,151
888
Winchester, UK
Contrary to reports, the second generation Chevy Volt is already under development
UK magazine AutoCar is claiming that the Chevy Volt and its European twins the Opel/Vauxhall Ampera will be one generation vehicles. After that the publication claims, the Voltec propulsion system will just be applied to other existing vehicles like the Astra. While Voltec will almost certainly be mainstreamed just as Toyota has done with its hybrid synergy drive, the Volt will apparently live on. GM spokesman David Darovitz tells ABG "there is about much truth to this as I am going to be in the next Superman movie. We're already working on Gen II." The Ampera may be a different situation however, as GM attempts to sell off controling interest in its European operations. That variant may fade away in the coming years.
vfx
14,790
40
CA CA
This guy has been bashing EVs and Teslas for so long I went into this piece expecting the worst.
He ends up with Tesla's business plan. Hilarious!
DP, you need to take back that JLP reference. This guy is a tool. The captain is not. :frown::biggrin:
Serge
190
2
Queens, NY
Chargers for the Volt
GM shows off 120V and 240V chargers for 2011 Chevy Volt - Autoblog Green
GM engineering specialist Gery Kissel explained that the 120V unit (seen right) has two charge rates. The normal rate is 12 amps, but if this causes circuits to break or other problems in the house, there is a user-selectable 8 amp charge option. The 240V charger has a 16 amp output, which is just over what the Volt's 16 kWh battery is suited for.
So the maximum charge rate Volt's pack is capable of taking is just 3.8kW?
vfx
14,790
40
CA CA
Met a guy last night who works at JD Powers. As you can imagine, they are car guys with a great perspective of what people like and buy.
He said he thinks the Volt will be a disaster and that he is not the only one there that feels that way.
malcolm
3,072
1,729
Any reasons given for the (apparent?) impending disaster? Admittedly GM aren't helping themselves with this 230 campaign, but where would they be without the Volt?
vfx
14,790
40
CA CA
He did not elaborate on why they were not bullish on the Volt (cause I didn't ask) but I got the impression at least part of it was about price point.
As for the Tesla, he had the grin...
Brent
243
5
Los Angeles, CA
Volt in NY Times
The NY Times has some nice things to say about a preproduction Volt.
Unlike many electrics, including the Tesla Roadster, the Volt’s electric drive has no whine. The car feels solid and planted on the road. Clicking the Sport button on the dashboard releases a bit more oomph than when in Normal mode; in terms of efficiency, there isn’t much difference between the two except at peak power.
Arnold Panz
Model Sig 304, VIN 542
Apr 13, 2009
1,340
3
Miami, Florida
Volt’s No. 1 Question: How’s Life After 40?
The NY Times gets the first test drive of the Volt prototype where the gas engine kicks in. An interesting review -- very favorable to the Volt, but clearly some kinks still need to be worked out. An interesting dig taken at the Roadster. Clearly, someone needs to come up with a better word than "whine" to describe the noise by the electric motor. :rolleyes:
stopcrazypp
9,936
4,850
Not only fishy but the fact they continue to compare extended range to BEV is daunting.
Volt was featured on NBC's Today Show. The follow-up video after Volt discusses Roadster.
Today Show Video Player
GM is deliberately doing that. They are focusing on "range anxiety" to hold back competitors like the Leaf. GM wants the benefits of both sides, they want to be called a legit "electric car" (for example the insistence that their car not be called a PHEV and inventing the term EREV), but they want to step on the pure BEVs that competitors are making.
For a company making a plug-in, they are the only ones focusing heavily on this point; even the hydrogen backers (Honda, Toyota) don't emphasize "range anxiety".
doug
Administrator / Head Moderator
Nov 28, 2006
16,894
1,015
SF Bay Area
I've seen that Tesla video before. I think it's from last spring.
In the Volt video, LeBeau mentions that the car's display indicates he's getting over 200 mpg, a number with little real meaning. I know it's been said before, but hopefully drivers can just get used to getting their power usage reported in Watts instead of MPG.
True. Their reasoning is clear, though. It's likely an effective marketing strategy for the type of vehicle that have chosen to produce.
