My kit in the trunk well has:
My kit in the trunk has:
- A card with the phone number for Tesla Roadside Assistance
@linkster, yeah, where did you get that spare?? And what size is it?
Mine's still in the glove box. At least it is most of the time. Sometimes it teleports to the trunk.My kit in the trunk has:
Though keep in mind that as you get close to the edge of the tire that's where the steel belts are and the belts will cut the plug like a wire saw as the tire flexes. So if the hole is amongst the belts a plug won't work.
My wife recently decided to take our 2-year-old son in for a "closer look" at some construction equipment at a site near her work. She ended up to 2 nails in one tire. One was in the center of the tire, the other was near the edge. I plugged them both and initially the tire held air. But after a day it started losing air again. The plug in the center was fine but the one by the edge was leaking badly. I removed it and it looked like it had been sliced. I did some poking around w/ the probe tool that came w/ my plug kit and I could feel (and just barely see) metal that looked like it was running the circumference of the tire. At that point I decided if I plugged it again it would just cut the plug again so replaced the tire.Thats not true. The steel belt crosses the entire tread. If its going to cut the plug it will cut it anywhere but the sidewalls.
But cut the plug or not, doesn't matter. The outside of the plug exists to keep water out of the hole, not air in. The inside of the plug exists to hold air in. Tire rubber is porous, it can't hold air. The only airtight rubber is the innermost coating. That is partly why I advocate wrapping the inside slack of the sticky rope on itself. This forms a large knot which won't pull out of the tire but as the tire spins this knot will flatten against the inside air barrier to produce a better air seal.
Also keep in mind that the Roadster's 12v outlet won't support the 12v air compressors since the amp rating of the outlet/fuse is underpar with the pumps requirements. For that I picked up a Black & Decker rechargeable pump. Just have to remind yourself to keep it topped off... worse case you can flag someone down to use the 12v option or even a 110v adapter.
When I got my flat, I considered the plug a temporary fix.
I took the car to my tire shop and they re-patched it from the inside.
You possibly could have gotten away with plugging from the inside.
I agree plugging from the inside is the most desirable solution. Only the inner layer of rubber is formulated to hold air so the key to holding air is to maximize contact with that very thin inner layer. Thats why I advocate twisting the tarry strips into a knot once one is through the tire to maximize contact with the inside of the tire. The rest of the plug only serves to keep dirt and water out of the inner layers of the tire. To keep water off the steel belts else they will rust.
I tested with a sissor jack from a 4 cylinder FWD coupe and it was not straining the jack. Of course better to find an 'unused' jack from a 6 cylinder mid-sized car - cheap at any wrecking yard. And just use for roadside emergencies, not for 4+ times per year rotations.
> it was so wobbly [jerry33]
That's because you didn't chock the wheels and the car rolled, or some other gross misadventure. The MS will not roll in PARK since the rear wheels are locked solid. Ditto Roadster with handbrake pulled hard. You can still get someone else to do the deed for you since you are carrying jack, spare wheel, lug wrench, etc with you. No need to call AAA to come 45 miles when every so often helpful handy people are cruising by who can do the deed for you with the hardware you have. They'll stop anyway and look sad if you tell them: 'I have no spare, no jack but I have called AAA'. So why not humor them by being prepared.
