Akikiki
A'-Lo-HA ! y'all
I just got mine in the mail today -- I hooked them up to an outlet with a 12v power adapter to see how they looked, and I have to say: they are pretty damn cool looking. I wasnt sure what I was going to do with them.... if they looked too cheesy, I thought frunk/trunk might be the way to go...if they looked cool, then do the door. Think I am going to do the door, especially since there is a drain plug and it all appears fairly straight forward in terms of install.
I do hope someone else posts step by step instructions while I am wait for me pry tools to come in the mail in the next day or so and decide to tackle it on my own. Anyone have instructions on how to remove the door panel??
An owner on TM (dleidy@spectrum) came up with an improvement in the idea of the logo light installation. Here’s a note of how he did it. He has pictures on his post on TM. (I too followed his lead. Works great.)
"I just popped out the stock puddle lights, pried out the black LED insert from the clear plastic housing, broke off the side wings from the clear housing, then used the hole saw supplied with the puddle lights to drill a hole in the factory clear plastic housing. Just put it on a board and drill slowly, I was able to just hold it with my fingers. The concentric circles in the plastic perfectly centered the drill bit.
You also have to slightly enlarge the hole in the door with a Dremel in order for the projector housing nut to fit up into the door. Connect the wires and snap back into place. "
Its great that we have so many people that can take someone's idea and move it along, often making the idea better each time. For those coming after:
After removing the existing plastic puddle light from the car, you must be careful drilling out the the hole. You wind up with about 1/16 or so of plastic on the sides. Once you slide the new lamp in and run the nut down it helps strengthen the plastic light. And you want it that way.
Enlarge the hole to allow the nut to pass through and it easily snaps in place. Say again, if you don't enlarge the hole for the nut, the lamp and plastic light will not fit gracefully.
You don’t have to cut the existing connector. Just add a clip it connector to connect the Logo light wires to the existing and you can undo all this if necessary.
